I have three link rooms with 3500's all fed off the masterlink from the BeoCenter 2.
(For info the BeoCenter 2 has an aux out to a separate non B&O amp and speakers)
The BeoCenter 2 (set to a.opt 1) is responding to the remote but does seem slow to respond.
Each 3500 has the standby display of the clock on. Each is set to l.opt 6
When i press radio on the remote (tried more than one remote) pointed at 3500 the speaker clicks on, radio flashes up on the display but then it returns to the standby display of the clock. Same with CD control. However, sometimes (becoming more often) nothing happens, i.e no click on etc. Same for all three speakers / rooms (one downstairs and two upstairs).
Have turned the system off for 30 mins so that i had to reintroduce the pin seeing if that would help clear any bug.
thanks
Christian
