        1st March February 2012
	    Latest post 08-18-2008 5:35 PM by  Peter. 16 replies.
								        08-14-2008 3:16 PM
									        gk31ax
								                - Joined on 04-18-2007
								                - Posts 220
										    Took the wife to look at a BV8-32 and she hated it, the BV6-26 was too small....Funnily enough she loved the BV7 and BV9 for that matter!!!    So whilst I save the pennies, I'm looking at possibly getting either an MX7000 or MX8000. I currently
have an MX4000 on a motorised table base and have an STB fitted, so
works brilliantly with Sky.  My questions are: Will my motorised base work with the MX7000, I think there are issues with the MX8000 and... Can I get my STB switched over to the MX7000 or will it only work with the MX8000? I also know an Avant would sort both issues, but I also have to think about where to put the BC2, Slingbox, Skybox, V8000 and now a Wii....BTW, if anyone has any sensible suggestion how I can get around plugging and unplugging Scart cables, that would be gratefully appreicated!   I know Neil will know all the answers!! Thanks Gary
									        Peter
								                - Joined on 02-12-2007
								                - Posts 9,572
										    Re: MX7000/8000 question...
										    The STB will swap - and just as well as you cannot get them any more!  Have you got a SCART expander - that will give you 3 SCART plugs and an RCA camcorder input.
									        lloydern
								                - Joined on 06-27-2007
								                - Oslo, Norway
								                - Posts 110
										    Hi Gary! Why don't you buy a Beovision 3-32...best television B&O ever made!!! Then you will also get widescreen tube.... Lloydern
									    Anything but Beo isn't an option...3-32, Overture, DVD1, Beomedia, V8000, lab 4000, 2 x lab 2000, 2 x lab 6000 & lab 11.
									        gk31ax
								                - Posts 220
										    Peter I do have the AV2 expander, but never have much luck getting it to work.....   I think it might be my actual scart cables though!   Lloydern Don't think I could get a BV3 as cheaply as the MX and whilst I agree the picture quality would be better on the BV3, lack of a motorised table stand is a big negative for me.
									        Peter
								                - Posts 9,572
										    I use an AV2 expander with my AV9000 (posh MX6000!) and it works fine.
									        lloydern
								                - Oslo, Norway
								                - Posts 110
										    Yes you can, motorised stand is no problem! The picture quality on the MX 7000 is poorly compared with the late versions of the Avant and Beovision 3. I cannot speak for the MX 8000.  I think buying av 4:3 set isn't somthing I would even consider for my living room tv. You gotta have 16:9. Just my opinion....    motorised stand here for you!
									        nobby
								                - Joined on 04-21-2007
								                - Posts 539
										    You will need a top plate to convert the MX4000 motorised based for the MX7000 ... probably these are available from your dealer ... or just buy a cheap floor stand from ebay and raid it from there.  The one from the 5000, 5500, 6000 or 7000 are ok. Personally I think 16:9 is massively overrated. The picture on my MX7000 is beautiful ... extremely easy on the eye and whilst of first impressions its not as sharp and bright as the avant ... it is far nicer to watch for extended periods. Neil
									        Meng
								                - Joined on 05-16-2007
								                - Posts 70
										    Has the Beovision 3 a good picture and a good sound? Just curious. Thought I read something else on this forum!
									        Peter
								                - Posts 9,572
										    The BV3-32 is very similar to an Avant 32. Slightly smaller speaker enclosures but not so you would notice. Very good and under rated set. The 28 is not the same at all and was a loss leader designed to get you into the shop. Nothing like the sound and the chassis is actually the late MX/BV1 chassis rather than the Avant. The only problem I have with these sets is the size - they are really very deep! The Avant gets away with it as it is free standing but the BV3 looks as though it is going to be a flat screen till you get round the back!
									        Dave
								                - Joined on 04-17-2007
								                - Brisbane, Australia
								                - Posts 2,328
										      lloydern:Hi Gary! Why don't you buy a Beovision 3-32...best television B&O ever made!!! Then you will also get widescreen tube.... Lloydern
I thought that too when i read the post!!
HERE HERE. The picture quality is utterly sublime.    And Peters comments are very fair, the back is the negative to the set, i've over come this by having the tv on a stylish bench in front of a window bay, so the rear of the tube disappears into the window sill, brilliant!  The sound is good for the size of the drivers, but not hi-fi, get the beolabs to do that job :)    [ignore the couch and table please]    Did you know you can get a motorised base to go with the BV3_32, (not the cabinet an actual module that fits under the set) you just need to look hard. I haven't found one yet, but until i do, it's not important, this is the best picture i've seen to date.
									        gk31ax
								                - Posts 220
										    Given that I want the BV7-32, the BV3 is too expensive for me at this point, also its depth is an issue.....   Here is my lounge set up at the moment, you can see the sofas either side of the coffe table (just) hence my need for a motorised stand! ![]()
									        lloydern
								                - Oslo, Norway
								                - Posts 110
										      nobby: You will need a top plate to convert the MX4000 motorised based for the MX7000 ... probably these are available from your dealer ... or just buy a cheap floor stand from ebay and raid it from there.  The one from the 5000, 5500, 6000 or 7000 are ok. Personally I think 16:9 is massively overrated. The picture on my MX7000 is beautiful ... extremely easy on the eye and whilst of first impressions its not as sharp and bright as the avant ... it is far nicer to watch for extended periods. Neil
 Hi again! Maybe it's different in UK, but here in Norway almost any tv-channels is broadcasting in 16:9. So here it is not overrated at all. If you have a 4:3 set like the MX 7000 you cannot control the format. And you are stuck with black bars on top/bottom, and you will also lose a little bit of the picture on each side!  To chararacterize the pictrue on a MX 7000 as beatiful????? Well, then you must be talking about with analog signals and not digital SD. With a digital set top box and SD signals (also DVD), the MX 7000 isn't in the same league as Beovsn 3-32 and 32 Avant! Finito! I agree that the deep back on the Beovsn 3 is a challenge, but the best way to hide that is to put in a corner! GONE!! I know this isn't a thread about Beovisn 3-32, I just got a bit eager here. Today everyone is buying cheap flatpanel televisions, but the thruth is if you have an Avant 32 or a Beovision 3-32 you will not get a better image before HD is standard on normal broadcasting! Lloydern
									        nobby
								                - Posts 539
										    A good analogue signal on an MX7000 will beat the Avant and BV3 hands down (in my opinion) any day of the week :) Most broadcasts in the UK leave you fiddling around with the format on the Avant (my main reason for not wanting to use one anymore) ... it was the shall I watch in format one and get side bars ... or format two and lose the top or bottom or format three and watch fat people ... none of which was satisfactory. When it comes to the snooker and other broadcasts that work so much better on 4:3 ... the 16:9 is left standing! One day, it will improve ... but that day has not yet come and meanwhile I am happy to enjoy my beautiful set, whose tube has already lasted 10 years and will be cheap and easy to replace when the time comes :) Over to you ;)
									        lloydern
								                - Oslo, Norway
								                - Posts 110
										    Hehehe! Well, I'm still not agreeing with you on the picture quality....but of course it is also a matter of taste! My main focus is the quality of digital SD signals, which almost anyone in Norway are forced to use due to new technology. If your set-top box leaves you with format problems only, I can see the problem. Extremely irritating! However, my set-top box goes very smoothly with my Beovision 3-32, and the format is always correct automaticly. (format 3 mostly). But I know som boxes doesn't match to well with Beos format options.  I mean of course that the MX 7000 is a great set, I've been using one myself for 12 years. But with my "new-used" cheap to buy Beovision 3-32 I recon what was a small step of improvement for you, became a giant leap for me!!!    I just love my television, now complete with surround sound, and I hope it will last for many years still. Because I have it in the corner, many people think it is a flat panel TV. And all of my guests are amazed with the picture.... Anyways...me first real "discussion" here on the forum. Great fun!!!!
									        nobby
								                - Posts 539
										    Format 3 for me was almost always the worst option! Neil
									        Peter
								                - Posts 9,572
										    I think it depends on what you look for in a picture. The 100Hz Avant and BV3 have quite a few digital artefacts which some people find objectionable. Each set is usually a compromise - for colour an old 3400SJ is great but you wouldn't want to use one every day.
        Page 1 of 1 (17 items)
