1st March February 2012
Latest post 12-17-2008 7:18 PM by Evan. 25 replies.
08-14-2008 11:12 AM
Milos Markovski
- Joined on 06-05-2008
- Serbia
- Posts 8
Hello, I have one very simple question. Since I have lost my beolink 1000 remote and I ain't gonna change my beosystem 4500(ever!), was wondering if I can control my system over beomaster 4500 with beo 4 remote. Thank you Milos
Weebyx
- Joined on 06-30-2008
- Denmark
- Posts 321
Haribo: Hello, I have one very simple question. Since I have lost my beolink 1000 remote and I ain't gonna change my beosystem 4500(ever!), was wondering if I can control my system over beomaster 4500 with beo 4 remote. Thank you Milos
Yes you can, Beo4 was intended as the replacement for Beolink 1000 But if i were you, i would see if i could find a used Beolink 5000 instead, then you will get 2-way communication and info/programming ability on the remote /Weebyx
benkap
- Joined on 04-16-2007
- Oslo, Norway
- Posts 162
Haribo, if I were you I would use a Beo4 and start looking for another Beolink 1000 if programming is needed. Weebyx has a point about the programming and two-way but the Beolink 5000 is just bad compared to the other two. It will continually loose contact, the range is not as good and it doesn't feel as good ergonomically. And IMHO two-way is not that big a deal. I have had a BS4500 and tried all three remotes working it but actually ended on Beo4 after all programming was done. Also keep in mind that your BM4500 might not support two-way. I forgot from which SW version two-way is supported but others will probably fill me in. Hope it helps :)
Weebyx
- Denmark
- Posts 321
Haribo: Thanx a lot for help. I bought Beo 4 yesterday and all works fine for me. Ergonomicly its just amazing, even better then heavy beolink 1000 imo.
Yes, if you don't need the programming options, then the Beo4 is fantastic. /Weebyx
benkap
- Oslo, Norway
- Posts 162
evman140: Can you program the radio stations/frequencies with the 5000?
Yes, you can. But if the BM4500 isn't a two-way version the BL5000 will effectively work as a flimsy BL1000. BM4500 supports two-way from SW 2.0 or 2.1 (can't remember which). I would definitely get a BL1000, it is excellent!
benkap
- Oslo, Norway
- Posts 162
evman140: bad news man, i already picked up the beo4 haha
The Beo4 is an excellent remote as well even though tuning radio stations on a BM4500 is not possible. Beo4 will work everyday functions perfectly so if you know someone who has a BL1000 you could borrow it for tuning and then use the Beo4.
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
look up at my previous post... follow the link it is about setting presets w/ a beo4! of course, if you really want a bl1000 -i have several!
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
I had a BM 4500 before and as far as I remember you don't need a rc to set the stations. You can use the panel of the BM to do so. Just look at this. Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
Kokomo
- Joined on 08-21-2007
- Spain
- Posts 618
kallasr: I had a BM 4500 before and as far as I remember you don't need a rc to set the stations. You can use the panel of the BM to do so. Just look at this. Ralf
You're correct, but it would be nice to be able to search/scan/ radio stations and store from the Beo4 something which was possible with the 1000.
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
burantek: look up at my previous post... follow the link it is about setting presets w/ a beo4! of course, if you really want a bl1000 -i have several!
i read the bit about the tv > v. setup > tune and it appeared as described, but did not work... if not which link?
Ignace
- Joined on 03-30-2007
- Moderator - NL
- Posts 2,749
Is A.SETUP already added to the List ? Although not directly relevant to tuning, it is handy for adjusting bass/treble/loudness/balance/sound store.
Christian
- Copenhagen, Denmark
- Posts 626
evman140: ...I do not have some of the buttons depicted in the manual on my touch panel. Such as "GO TO", "STORE" (they are displays in green however), or the "<" & ">"...
These are buttons. They only appear when needed, and yes - they are green.
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
Ignace
- Moderator - NL
- Posts 2,749
evman140: Yes, it is. By the way I just shot you another email. When attempting to tune it (BM4500) via touch panel, according to the manual picture, I do not have some of the buttons depicted in the manual on my touch panel. Such as "GO TO", "STORE" (they are displays in green however), or the "<" & ">", just volume up and down arrows.
They appear in green when you touch PROGRAMMING
Ignace
- Moderator - NL
- Posts 2,749
Yes, they are. You use them to tune the radio and store settings. The BM4500 shows the available buttons after you press PROGRAMMING.
Ignace
- Moderator - NL
- Posts 2,749
They should appear when you touch the green GOTO the options you have : - < / > : auto search - 0-9 : manually enter the frequency - AM/FM : switch bands - STORE : store current frequency and so on.
Do you have the manual ?
