Latest post 08-20-2008 2:32 PM by Puncher. 5 replies.
Page 1 of 1 (6 items)
  • 08-13-2008 12:46 PM
    PC like problem on my Mac
    Dear Mac boffs and lovers,
    It has now been a month or so that I cannot transfer photos from my Nikon camera to my MacBook. I plug the camera in via USB and the MacBook does not register it whatsoever. I have tried plugging it in to a friend's PC and it finds the USB connection immediately and works fine. I am wondering whether a software update might have disrupted something, but I cannot remember doing a software update of any sort recently ... unless they happen automatically.
    The USB inputs all other devices that I use via USB. I would appreciate any help or suggestions.
  • 08-13-2008 12:49 PM In reply to
    Re: PC like problem on my Mac
    Are you using the same memory card? Try downloading the pictures elsewhere - your friends PC seems as good as anywhere! Laughing - then format the card. That might fix it!
  • 08-13-2008 3:04 PM In reply to
    Ah yes! I bought a new SD card for the Nikon. I didn't have to format the previous SD card, but I shall have a go at this tonight.
  • 08-14-2008 2:51 PM In reply to
    Thanks again Peter, problem solved! Smile
  • 08-14-2008 3:08 PM In reply to
    My Goodness! I fixed a computer problem! Laughing Now that must be a first!
  • 08-20-2008 2:32 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Peter :
    Strictly speaking it was a memory card problemStick out tongue
