Latest post 08-16-2008 4:59 PM by Dillen. 8 replies.
Page 1 of 1 (9 items)
  • 08-13-2008 8:39 AM
    Beogram RX2 problem
    Hello
    I found this turntable in our cellar, so it may be damaged.
    When I press play the table starts spinning but then stops shortly after the needle gets in position, is there any way I can fix this problem?
  • 08-13-2008 1:15 PM In reply to
    Re: Beogram RX2 problem
    ... and there is a record on the table? Without a record it will stop, it's a safety function for the needle :)
  • 08-14-2008 10:09 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Die_Bogener is correct in that it won't start without a record. It will just rotate the platter a couple of times without moving the arm.
    However, if the Beogram hasn't been used for a long time, it may seem to start correctly, swing in the tonearm and lower but then lift and stop right after the needle has landed on the record. This is due to oxidation on contacts inside and in most cases it will wear off in normal use.
    The correct thing to do is to have it serviced, cleaned etc. but you can also try playing a record several times, maybe 20 times or more and see if it starts behaving correctly.
    The above applies to all the Beograms in this series, Beogram RX, RX2, 1800, 2000, 5000 and derivate Beocenters.
  • 08-14-2008 10:53 AM In reply to
    Hi.
    Yes, I have a record on it =)
    Well, I guess I just have to service it, how much do we talk costwise?
  • 08-15-2008 11:36 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Steelsky:
    That all depends on what the problem is and where you take it.
    To be honest it could be cheaper to buy another turntable off ebay.
    Chris.
  • 08-15-2008 12:24 PM In reply to
    • Dillen
    • Posts 5,008
    Did you try the alternative ?
  • 08-16-2008 12:48 PM In reply to
    Absolutely! Then you could get a cheaper price because you were having 2 serviced at once.
  • 08-16-2008 4:47 PM In reply to
    Phil Hunt:
    Laughing  It is a problem with Beograms and eBay !
  • 08-16-2008 4:59 PM In reply to
    • Dillen
    • Posts 5,008
    Your decision completely, though I find it hard to believe that finding another Beogram at Ebay would be cheaper than hitting the play button some 30-40 times.
