Latest post 08-12-2008 5:09 AM by Peter. 4 replies.
Page 1 of 1 (5 items)
  • 08-11-2008 6:28 PM
    Aluminum polish ?
    I've just purchased a Beocenter 7700 and I'd like to clean it up. Is there something I can use to clean and polish the brushed aluminum on the top ? Any other cleaning suggestions also. I'm in the U.S. so it has to be something I can get here and would a Dremel polishing kit be safe to use ?
  • 08-12-2008 2:01 AM In reply to
    Re: Aluminum polish ?
    BS1 x 2, BS 3, BS4, BS2000 x 3, BS2300, BS4000, BS9000, BL4, BL 4000 x 2, BL8000 x 2, BL2500 x 2, BL2000, Beocom 2, Beocom 6000 x 4, Beocom 1401 x 4, Beocom 1600 x 2, Beocom 2500 x 4, Beotalk 1200, A9 Keyring, Beo4 x 8, Beotime, Bottle Opener
    2011 Wish List: BL3500, BL6000, BL5, BL9, active link, BS5, Beo5
  • 08-12-2008 2:23 AM In reply to
    I have been using iKlear Apple Polish for some time now on my beolabs and beosound, plus all the Ipods I have owned with a stainless steel polished back. No problem, worked like a charm.
  • 08-12-2008 4:17 AM In reply to
    • Dave0280
    • Top 500 Contributor
    • Joined on 03-05-2008
    • Birmingham, UK
    • Posts 126
    • Gold Member
    I'm just cleaning up a pair of Beovox aluminium cased speakers and use Autosol - superb. Ebay has loads of it and cheap too.
    Dave - Birmingham, UK
  • 08-12-2008 5:09 AM In reply to
    Do be careful with anodised surfaces! Abrasives will simply get you to plain aluminium and that will not be the same at all!
