Latest post 09-26-2008 7:14 PM by B&Ola. 8 replies.
Page 1 of 1 (9 items)
  • 08-11-2008 4:57 PM
    Beocenter 9000 CD issue
    Please give me some ideas of what could be wrong with the CD-drive on a BC9000.
    When putting in a CD and press CD or LOAD the door closes and it spins up for a second. Then it stops and the door opens.
    Any clues? Does the CD-drive needs to be replaced? Is a spare still available?
    /Ola
  • 08-11-2008 5:26 PM In reply to
    Re: Beocenter 9000 CD issue
    I am afraid that new cd drives are no longer available. You could try cleaning the laser lens but  I am pretty sure that the problem will be some dried out capacitors on the cd servo board, in particul;ar C2103.
    There have been a number of threads on the forum and a search will reveal the info you require.
    Regards Graham
  • 08-12-2008 6:27 PM In reply to
    OK, thanks.
    Cleaning didn't do the job so next thing will be handing it in for service.
    /Ola
  • 08-13-2008 2:41 AM In reply to
    It is more than likely that an ordinary B&O service centre will pronounce your 9000 unserviceable. You should try to find someone who is used to repairing vintage B&O who will be familiar with the well publicised fixes for 9000 CD problems.
    Regards Graham
  • 08-18-2008 5:43 PM In reply to
    Thanks Graham for your replay. I tried to find a service manual for the 9000 but it seems to be missing.
    I have also done some search but I can't find so much information about the 9000 CD-issue.
    Do you know where I can find more information about the c2103 location on PCB etc?
    Best Regards
    Ola
  • 08-19-2008 4:15 AM In reply to
    C2103 is on the servo board which is attached to the bottom of the CD mechanism. It is a 33uF electrolytic. There are a couple of other electrolytics on the board and it is worth changing those as well.
    It is difficult to find 33uF nowadays so I use 47 with success.
    The BC9500 service manual is on site and the servo pcb is identical on that model.
    Regards Graham
  • 08-19-2008 11:15 AM In reply to
    I was working on it yesterday and think I found the capacitor It's mounted in line with a resistor and the spec is 16v 33uF and it looked like this one had it's days...
    How important is the brand of the capacitor? The one on the PCB is a Philips. What do you use?
    Should it be a bipolar? Is that of any importance?
    Thanks again for your help!
    /Ola
  • 08-19-2008 11:49 AM In reply to
    I have had varying success rates but see this thread for comments by the experts.
    http://forum.beoworld.org/forums/thread/106444.aspx
    Regards Graham
  • 09-26-2008 7:14 PM In reply to
    Hi After great help from Martin, Dillen, the CD works fine again. Thank you! /Ola
