Latest post 08-18-2008 3:04 AM by Peter Pan. 12 replies.
Page 1 of 1 (13 items)
  • 08-11-2008 3:05 PM
    Beovision 7-40 MKII versus MKIII (Full HD)
    Hi everyone, and thank you so much for reading my first post and maybe replying!
    I grew up with B&O, but has since wandered around this and that ending up with a complete lineup of Pioneer plasma and audio, as well as Canton Vento speakers. Now everything is thrown overboard, and I am back to B&O. A good friend is selling his Beovision 7-40 but not the full HD one. And that is where I am about to have an issue.
    My friend knows about these things, as do I. His opinion (of course - being the seller) is that one should not exadurate the importantness of a Full HD screen compared to the one that is not. Also, as a Blu-Ray replacement is likely to show up as a DVD replacement I figure that the sound decoding is perhaps somewhat important. The MKIII with it's Beosystem 3 module decodes a few more formats as I understand it. Furthermore the one my friend sells is not upgradeable? Can anyone confirm this?
    The issue here, money aside, is if I make a nice buy on an older Beovision 7-40, or if it should be a "hands-off" compared to the new full HD one. My worry is that I will regret it if I buy the "lesser" one.
    Finally - he is selling with the 7-2 loudspeaker. I was thinking of buying a pair of Beolab 1's as well to go alongside it. Is that a complete overkill or just a nice setup?
    Thank you in advance to anyone who sees fit to help me out. It's not all black, but I could use some light!
    BV 7-55, BL 7-4, BL 9's, BL 4's, BL 3's, BC 2300, Beo5, Beo4
  • 08-11-2008 3:59 PM In reply to
    Re: Beovision 7-40 MKII versus MKIII (Full HD)
    Hvorfor skriver du på engelsk i et skandinavisk forum?
    /Frank
  • 08-11-2008 4:20 PM In reply to
    • tIRED
    • Not Ranked
    • Joined on 05-27-2008
    • Posts 32
    Jag skulle inte köpa den gamla om jag var du. Jag har en (eller tre, rättare sagt) MKII:a och jag retar mig konstant på dess brister och tillkortakommande (vilka du kan läsa mer om i andra trådar i detta forum). Om jag varit du hade jag väntat till den modell med Blueray-spalare kommer (inom kort), ev. kallad MK4. Just nu är det ett sammesurium av tveksamma kombinationer i MKIII:an.
    Beträffande uppgradering av MKII:an så beror det lite på vad man menar. Om man syftar till mjukvaran så kan man mycket väl uppgradera den. Dock inte DVD-spelaren (till t.ex. en Blueray-spelare..). Dock skall man inte förvänta sig att de uppgraderingar som kommer till MKII:an och MKIII:an kommer göra någon större skillnad. Det är inte direkt frågan om feature-uppgraderingar utan snarare fixar av uppenbara fel. Jag anser t.ex att det faktum att mina MKII:or inte stödjer vanlig kalle anka-PCM (digital stereo) via SPDIF:en (vilket är desto viktigare när man inte har en riktig HDMI-ingång (vilket MKII:an inte har, dock DVI med alla begränsningar det innebär) är en "bugg". Det tycker inte B&O som inte har några som helst planer på att fixa detta (trots att det hade varit bus-enkelt givet att SPDIF:en t.ex. klarar 3 och 5 kanals digital "stereo")... En liten detlaj som kan ställa till _stora_ problem.. Tro mig.. (läs en av mina andra postningar där jag beskriver varför detta är så struligt för mig). Men men, B&O i ett nötskal... Kolla på blocket.se (eller liknande beg. siter) om du vill ha en 7-40. Kan slå vad om att det säljs en och annan MKIII:a där (om du nu vill köpa tvn nu och inte vänta på en kommande MK4:a).
    Ang. 7-2:an så blir det bra. Det är en väldigt trevlig högtalare och jag har den t.ex. som enda högtalare på min 7-40 i sovrummet (vilket räcker väldigt fint, tycker jag). Lägg till ett par Beolab 1:or så får du ett jävla ljud. Lägg till ett par 6000 eller 4000 som bakhögtalare så kommer du väldigt långt (på vägen till ett super-bio-ljud i vardagsrummet).
    /tIRED (of my corrupt $100.000 setup)
    Filed under:
  • 08-12-2008 2:31 AM In reply to
    frankmj:
    /Frank
    Dette var vel i overkant off topic Frank?? Det er mange forum under Beoworld, og jeg tenkte at da kunne kanskje også øvrige brukere finne på å svare. Jo flere jo bedre.
    Finn deg noe viktig å tenke på ;-)
  • 08-12-2008 2:39 AM In reply to
    • Helge
    • Not Ranked
    • Joined on 05-19-2008
    • Posts 1
    Min påstand er at man ikke trenger full HD på et tv av størrelse 40". Det som man imidlertid kunne ønsket seg var HDMI innganger. Det lar imidlertid greit ordne ved å bruke DVI. Har selv et Beovision mark II som jeg er strålende fornøyd med. Så om du er opptatt av bilde kvalitet og ikke av tekniske spesifikasjoner er absulutt ikke Beovision 7-4 mark II et dårlig valg. Hvor og eventuelt når Blue ray overtar for valig DVD format filmer er vanskelig å spå noe om, de fleste menesker jeg jobber sammen med vet enda ikke hva blue-ray er !. Husker selv godt hvor viktig det var med 100 Hz og viktigheten av å kunne spille SACD , disse tingene er i dag ikke lengre noe tema, så igjen hvis du ønsker et godt bilde uten å være spesifikasjons frik så vil du kunne ha stor glede av et beovision markII.
  • 08-12-2008 4:01 AM In reply to
    Off topic? Overskriften til dette forum hedder: Beoworld Skandinavian!
    Hvis du vil have flere til at læse dit indlæg, så skriv dog i det generelle forum. Ellers er der jo ingen grund til at have et skandinavisk forum.
    /Frank
  • 08-13-2008 2:19 PM In reply to
    tIRED:
    Tusen takk for svar! Tar dette med i den videre vurderingen.
  • 08-13-2008 2:21 PM In reply to
    frankmj:
    /Frank
    Kommentarer til hvilket språk jeg skriver på er ikke relatert til B&O på noe vis, og derfor off topic uansett hvordan du vrir og vender på det. Men bevares....
    Og jo... Skandinavisk forum kunne meget vel hatt med spesifikasjoner etc å gjøre.
  • 08-14-2008 4:32 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Det skandinaviske forumet skal hovedsakelig dekke brukere som ikke er komfortable med å skrive på engelsk og saker som har geografisk begrenset interesse (f.eks. stying av STB'er som kun brukes i Norge, Sverige og Danmark).
    Dessverre dukker det stadig opp interessante artikler på disse "country specifc forums", som nyheter knyttet til et produkt på det franske eller nederlandske forumet - irriterende - og vi henstiller til at slike ting skrives på General Forum (på engelsk, selvsagt).
    Roger
  • 08-14-2008 11:55 AM In reply to
    Roger:
    Roger
    Da hadde jeg jo litt rett da.. at det kunne være regionspesifikt, men skal skrive på norsk heretter dersom jeg skriver i skandinavisk forum.
  • 08-18-2008 1:59 AM In reply to
    Tak  takktakk
    Roger vi er dybt uenige.
    Med din holdning vil det Skandinaviske
    forum blive uinteressant at læse og dø.
    KØB B&O.
    Mvh Peter Pan
  • 08-18-2008 2:15 AM In reply to
    • Roger
    • Norway
    • Posts 870
    Jeg skjønner frustrasjonen.
    Vi gikk mange runder da BeoWorld fikk ny "template" på hvorvidt vi skulle droppe "BeoWorld in your language", nettopp fordi vi til tider har få diskusjoner gående og de bør holdes på General Forum hvor alle våre medlemmer kan delta. Det er dessverre slik at engelskkunnskapene i Skandinavia ofte er bedre enn andre ikke-engelsktalende land, og vi (BeoWorld) ønsket ikke å sette medlemmer med dårlige engelskkunnskaper i en situasjon hvor vi ikke kan tilby hjelp.
    Dette veide tyngre enn å blokkere muligheten for at interessante diskusjoner av allmenn interesse ble holdt på utelukkende tysk, nederlandsk, fransk... Så får vi heller leve med at detaljer rundt BeoSound 5 / BeoMaster 5 nå er lekket på et ikke-engelsk forum og ta edit-jobb med å få dette inn i General Forum.
    Roger
  • 08-18-2008 3:04 AM In reply to
    Tak Roger
    Det er et godt kompromis.
    Mvh Peter Pan
