Latest post 08-01-2008 9:52 AM by lausvi. 10 replies.
Page 1 of 1 (11 items)
  • 05-11-2007 12:40 PM
    • EOB
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 188
    second hand Serene
    What should i be looking for when i buy a second hand Serene ( not from a dealer ). what are the pitfalls ?
  • 05-11-2007 1:32 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: second hand Serene
    Make sure the software has been updated. There were a few issues with the early ones..
    Lee
  • 05-11-2007 6:21 PM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    may be a stupid question, but I don't know: are there differences for mobile phones as for the AV equipment between different countries?Hmm
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 05-11-2007 6:29 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    As far as i'm aware, the Serene is SIM free and can work in any country. Isn't it Tri or Quad band or something?
    Lee
  • 05-12-2007 2:51 AM In reply to
    Check the call log, > the talk time the previous owner had put on.  I just got my second hand and the previous owner didn't reset his call log (I hope) and it had 9hrs outgoing and 5hrs incoming.  I found out it was brought in last June cuz it had the warranty sticker on the battery. And apparently, I found out the pictures naming was save in sequence (SP_A0001...0002 so on), so you can find out how many pictures it took by taking a pic and see what the number is. < I haven't found out where to reset that though.
    Davidson
  • 07-30-2008 8:41 AM In reply to
    Any other thing we should be aware of when buying a used one?
    Is there a way to check the serial, to see if it was stolen or something like that. And can B&O supply a new battery - for how much?
    What is the latest software number and how do you check it on the phone? And has anyone figured out how to reset it - delete absolutely everything on the phone? I got an offer, but I'm very reluctant on buying it... I had a bad experience once and I want to be 100% positive.
    Thanks.
    PS. what is the safest way to transfer the money, if the seller doesn't have PayPal? So you can get you money back if it turns out to be a scam?
  • 07-31-2008 3:30 AM In reply to
    Hi I bought a brand new serene off ebay sealed in box never even charged once...I paid 500 euros which i think is a great deal.
  • 07-31-2008 8:44 AM In reply to
    Thank you for that, but somehow it doesn't really answer any of my initial questions... Anyone?
  • 07-31-2008 10:05 AM In reply to
    • Blak
    • Not Ranked
    • Joined on 12-09-2007
    • Posts 42
    the lastes software is
    E910-XX-FI1
    E910-XE-FI1
    E918-ZC-FI1
    E910-DX-FI1
    E910-JV-FI1
    despens on there youre from...
    but it all end on FI1
     to show sw press *#1234# on the phone
  • 07-31-2008 5:50 PM In reply to
    • pgerell
    • Not Ranked
    • Joined on 05-24-2007
    • Stockholm
    • Posts 77
    9 LEE:
    Lee
    If it is not updated, can't I just have it updated myself?
    My phone has version E910-XX-FA2. Does anyone know what kind of problems are resolved in later versions.
    /Peter
  • 08-01-2008 9:52 AM In reply to
    • lausvi
    • Top 150 Contributor
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    I was just last week at my local B&O store and asked about the Serene's software updates. I have also bought my Serene second hand (from eBay and around 540 EUR). The latest update was (I think) 2006 and I was told that it's main thing is that makes Serene calender to sync with Windows Vista -based PC as that has been impossible with the old software. I don't know if the update has any smaller things included. If anyone knows better please tell!
    Bang & Olufsen - The art of controlling sound, picture and light
