1st March February 2012
Latest post 08-10-2008 11:03 AM by rotel18. 10 replies.
08-09-2008 2:39 PM
rotel18
- Joined on 08-09-2008
- Posts 20
Please help me, i want to connect my beolab 3 speakers to my amp.....
i have looked all over the net for a way to do this but with no joy. I received them just as they are with no cables, i understand about the mark 3 cable etc. What i want to do is connect them to my amp, is this possible, is there a wire to connect them to speaker terminals? Many thanks.
Sasha and Digweed fan! Progressive Melodic House!
jk1002
- Joined on 04-16-2007
- Boston USA
- Posts 1,620
Re: Please help me, i want to connect my beolab 3 speakers to my amp.....
They have an Amp integrated, so you need to look for a regulated line out on your amplifier. Most likely (if it has that at all) that would require a cinch connection. While powerlink to 3.5mm stereo are quite frequent and available on ebay, powerlink to cinch I havent seen but you could get that with another adapter inbetween. I would ask my dealer, he can probably supply you with one. There is a good chance though, that your amplifier may not offer a regulated line out ... what is that model? Cheers
Alex
- Bath & Cardiff, UK
- Posts 2,990
A model number would be helpful, not all amplifiers have variable line-level (called pre-amp) outputs, although virtually all have line outs intended for use with a tape player/CD recorder, but these must not be used as they run at full volume all the time!
Weekly top artists:
rotel18
- Posts 20
Hi thanks to both of the responses, my amp is the rotel RA-02. Could someone tell me what cable i would need to run them off my laptop, they are meant for pc/laptops i hear. Cheers.
Alex
- Posts 2,990
The cables are called PowerLink to Line adapters or cables I believe. I used a pair with BeoLab 3s to connect to the pre-outs of one of my Rotels and they work well. The RA-02 has a set of pre-outs (in fact it's an exceptionally well specced amp) which are perfect for driving your BeoLab 3s.
Weekly top artists:
rotel18
- Posts 20
Many thanks alex, i will have a look for those cables and now i have confirmed the amp can drive them im rather pleased!
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
If you get the cable in your link, you will also need a Powerlink splitter as you cannot diasychain BL3's according to the manual. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Craig
- Posts 4,855
rotel18:
Yes, they seem to be perfect for the job. As you correctly say, one for the left and one for the right. Craig
rotel18
- Posts 20
Fantastic! Thanks to all who helped me out on this, you lot are very welcoming to a newbie such as myself with b & o products..... I shall get to purchasing this cable asap. Im currently running sansui s-915's, which are perfect, these should compliment my setup nicely. Thanks!
Page 1 of 1 (11 items)
