Yes, when first some of the traces break, the others will follow shortly.
You can take off the top cover, that fairly easy; Losen two screws at the rear a couple of turns each, slide up their brackets and tighten the screws again.
The top cover can then be pushed a bit towards the rear and lifted up.
Accessing the innards of the front panel is a rather more complex task and describing it here would turn this post into a novelle.
The service manual is available for download for silver and gold members, well worth the membership fee for the amount of info there. Furthermore, gold members automatically enter the monthly prizedraw, which is easily worth the membership fee alone.
