I just got home from work and switched everything on at the powerpoint, as i do, and while everything was sitting in standby, my left bl4000 was making an arcing sound and the light was glowing yellowy greeny reddy (as if it was being electrocuted)! When i power up the music system, the speaker stops arcing and operates green and sounds as it should!
Is this going to be an expensive fix, has anyone experienced this? I'm assuming the switch's power supply, in the loudspeaker has had it... :(
This is my first out of warranty B&O fault - I'm worried
