Latest post 02-22-2009 12:48 PM by ouverture. 13 replies.
Page 1 of 1 (14 items)
  • 08-06-2008 8:58 PM
    DVD controller?
    I have heard about such a device that allows me to use my Beo4 with a non-B&O DVD player.
    Anyone have any details?
    Cost?   (available in the US?)
    -michael
  • 08-07-2008 1:55 AM In reply to
    Re: DVD controller?
    Possibly not very useful in the US as it is a glorified SCART lead with a power supply and an integrated IR eye. Relatively limited number of supported products but works quite well. About £150 in the UK. Seems to have been overtaken by an improved STB-C called the PUC (Peripheral Unit Controller).
  • 08-07-2008 2:44 AM In reply to
    Re: DVD controller?
    The following DVD Players are supported by the DVD Controller Mark II
    Onkyo DV-S525 02
    Panasonic DMR-E50 06
    Panasonic DMR-E53/DMR-E55 07
    Panasonic DVD-A360 01
    Panasonic DMR-EH54D 16
    Philips DVD950 00
    Philips DVDR70/DVDR75 03
    Philips DVDR80 04
    Philips VR200 09
    Philips HDRW720 13
    Pioneer DVDR-3100 05
    Pioneer DVR-530H/DVR-630H 15
    Sony RDR-GX3/RDR-GX7 08
    Sony RDR-HX1010 17
    Sony RDR-GX210
    Regards Keith....
  • 08-07-2008 4:15 AM In reply to
    • deaddruid
    • Top 500 Contributor
    • Joined on 05-24-2007
    • Malvern, Worcestershire
    • Posts 247
    Re: DVD controller?
    I thought that there were different versions of the DVD controller for different manufacturers' DVD players. Did I misunderstand? Mark
  • 08-07-2008 6:57 AM In reply to
    Re: DVD controller?
    Mark,
    There is just two versions of the DVD controller Mark I & Mark II with the software being the key difference
    If you have a Mark II DVD controller, the software can be updated which allows the support of the previously quoted DVD players.
    It should be noted that many other DVD players will work, but have never been tested by B&O.
    Regards Keith....
  • 08-07-2008 10:59 AM In reply to
    • deaddruid
    • Posts 247
    Re: DVD controller?
    How do you tell whether you are being offered a Mk I or a Mk II? I take it from your comment that the Mk I is tied to a particular manufacturer (so you need to ensure you get the right one), whilst the Mk II supports all five - is that correct? Mark
  • 08-07-2008 11:17 AM In reply to
    Re: DVD controller?
    http://shop.oneremote.dk/catalog/index.php?cPath=38
    I haven't tried these, but might be worth to take a look.
    Cheers
    JK
  • 08-07-2008 11:40 AM In reply to
    Re: DVD controller?
    The Mk2 is just an updated version of the Mk1. A new one will always be a Mk2.
  • 08-07-2008 4:12 PM In reply to
    Re: DVD controller?
    Are the dvd controllers still available. The production has stopped i tought.
  • 08-07-2008 7:25 PM In reply to
    Re: DVD controller?
    I here you guys talking about SCART all of the time - but what is it?
     Is it different than HDMI?
    Or is this just another of a long line of B&O stuff that is not available in various 3rd world countries like the U.S.?
    -michael
  • 08-08-2008 1:45 AM In reply to
    Re: DVD controller?
    SCART plugs are a European standard connector - Have a look at this page.
  • 08-08-2008 4:06 AM In reply to
    • deaddruid
    • Posts 247
    Re: DVD controller?
    Having looked at the site which JK suggested, it seems that the 3rd party controllers translate control signals from the SCART on the back of the TV into the right signals for a particular DVD player. Does that mean that the SCART port needs to be set to DVD1? Does this mean that you couldn't share the same SCART for a controlled DVD and a STB controlled by STB-C, since each port can only be set to *one* of these input types? Mark
  • 01-26-2009 9:24 AM In reply to
    • k984942
    • Joined on 11-10-2008
    • London, UK
    • Posts 194
    Re: DVD controller?
    How can you tell if you have a mark I or mark II?
    32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
  • 02-22-2009 12:48 PM In reply to
    Re: DVD controller?
    Hi Keith,
    you mention that the MKII can work with the Onkyo DV-S525 model, but that model does not have a scart connector, so I think this could be a typo, I believe it should be the Onkyo DV-S535, which is a fine DVD and CD player that uses Burr-Brown DAC's, so the sound quality is superb !
