Latest post 08-07-2008 4:06 AM by joeyboygolf. 2 replies.
Page 1 of 1 (3 items)
  • 08-06-2008 4:34 PM
    • Kaa000
    • Not Ranked
    • Joined on 07-15-2008
    • Posts 8
    Beocenter 9000 MUTE RELAY??
    How can I clean/lube my beocenter's mute relay? It has some kind of plastic "shield" and
    I couldn't get it off because I was afraid that it will break.. :)
     -Kaa
  • 08-06-2008 6:04 PM In reply to
    • magnushj
    • Top 500 Contributor
    • Joined on 08-16-2007
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    Re: Beocenter 9000 MUTE RELAY??
    I had to solder mine out and pry it open with a screwdriver. Very fiddly job. The plastic has become very brittle with age, but if you crack it, you could always just tape it back together or just buy a new relay. I believe they are available as a spare part.
    Beocenter 9500+Beolab Penta mk2+Avant+MX7000+Beosound Ouverture+1xBeolab 6000 :)
  • 08-07-2008 4:06 AM In reply to
    I have not found cleaning effective for more than a day or so. The relay is available as a spare part from B&O or I'm sure you can get a substitute from an electronics supplier for 10% of the B&O price!
    Regards Graham
