Latest post 08-06-2008 9:21 AM by Medic394. 2 replies.
Page 1 of 1 (3 items)
  • 08-06-2008 8:47 AM
    Beosound 1
    Hi all i have a Beosound 1 and i would like to know if you can change the colours of the front grill. If it's possible how do you go about it.
    Many thank's
  • 08-06-2008 9:08 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Beosound 1
    The grille can just be removed, and you can get another colour if you wish. Just squeeze the grille a little on either sides, and slide it up. It's not the easiest thing in the world to do, but it's not designed to changed as often as your socks!
     Weekly top artists:
  • 08-06-2008 9:21 AM In reply to
    Re: Beosound 1
    Hi Alex thank's for the quick reply i will try that.
