Latest post 05-13-2007 4:28 PM by -multimedia Robert-. 4 replies.
Page 1 of 1 (5 items)
  • 05-11-2007 10:16 AM
    Technical Help needed with Beolink 7000
    Hi Beolink 7000 helper,
    My Beolink 7000 got ill after 16 years admiring usage. The problem: “No contact”
    The symptoms are: The remote receives no 2 way information. The blue display blinks! (only when a touch button like volume up or down is used) (The battery is 100%)
    My Beomaster 7000 works 100%, I have tested my beomaster with a second BL7000.
    My B&O dealer, the technical department, asks me to contact Beoworld helpers if someone can give a possible clue….(My Beolink 7000 is at my dealer now)
    Who can help me?
    Regards, Robert
    Filed under:
  • 05-11-2007 10:31 AM In reply to
    Re: Technical Help needed with Beolink 7000
    Very specialised. The normal method of fixing is to replace modules - the service manual is on site (I think!) but is not very helpful. I believe Ridax fixes these - or can - though I have not seen him on site yet. This is definitely not one to just have a go at fixing yourself.
  • 05-11-2007 6:53 PM In reply to
    • PL212
    • Top 200 Contributor
    • Joined on 02-14-2007
    • Moderator - Seattle
    • Posts 318
    I'll quote from Cozza on the old board talking about a similar problem, as I don't know if he's re-registered here:
    "Sounds like you need to replace the two SMD electros shown in this picture. Make sure that you clean the circuit board thoroughly with Isopropyl alcohol, as they have likely leaked electrolyte on the circuit. I have had to do this to both my beolink 7000s, and it fixed them both of the "no contact" symptom.
    22 microfarad, 6.3 volts. Higher voltage may be used, provided the physical dimensions are similar. 4mm diameter, 6mm height."
  • 05-12-2007 6:58 PM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-17-2007
    • New Zealand
    • Posts 119
    The most likely problem with your Beolink 7000 is the capacitors in the infrared receiver, it seems to be a common fault. If you pass this information to your dealers technician, he may be able to fix it for you.
     The capacitors are visible through a hole in the shielding box around the infrared receiver.
     If the blue display backlight blinks when you press a button, there may be more than one fault in your unit.
  • 05-13-2007 4:28 PM In reply to
    Hi PL212 and Cozza
    Thank you very much for helping. I will contact my repair man at the B&O dealership and give your advises.
    Great help !!
    Regards Robert
