Latest post 08-04-2008 6:11 AM by dimka. 3 replies.
Page 1 of 1 (4 items)
  • 08-02-2008 10:20 AM
    • dimka
    • Not Ranked
    • Joined on 08-01-2008
    • Posts 13
    • Silver Member
    Power Reset Button for Penta Speaker,Maybe?
     Hi again,
    I am wandering if there is a reset power button for the Penta 3 speaker. I believe electrical surge have killed the speaker at list something in the speaker as does not want to turn on. I was looking for a reset button but could not find it.Please help if anyone  have an advice for this problem.I always believed that there is a some protection on the B&O speakers before they blow up or power surge damage occurs.
    dimka
  • 08-02-2008 10:57 AM In reply to
    Re: Power Reset Button for Penta Speaker,Maybe?
    Not on the Penta I am afraid. It may have blown a fuse if you are lucky. If not experienced in electronics, take it to someone who is. The internal packaging in the Penta amplifier is quite fragile and getting more so with age. The service manuals are on site though.
  • 08-02-2008 4:07 PM In reply to
    • dimka
    • Not Ranked
    • Posts 13
    • Silver Member
    Thanks for the info Peter,
    I will look up for the service manual.
    Dime
  • 08-04-2008 6:11 AM In reply to
    • dimka
    • Not Ranked
    • Posts 13
    • Silver Member
    Hi Peter,
    Thanks again for the help. I looked it up the service manuals. Yes I was lucky only the fuse(s) is blown.I swapped the fuses from the other Speaker and "bingo" it worked.I wander where I should buy these Penta  fuses (2).Any idea?
    regards,
    dimka
