Easy, look on the top and you will see two lugs.
Now, place your hands underneath the 9000 and lift towards you taking care and when you get to around 45 degrees you should be able to lift off clearing the two lugs.
Take care when doing this as the rear mounting plate must clear the lugs or you will end up pulling the damn thing off!
