Latest post 08-05-2008 8:35 AM by twadle. 5 replies.
Page 1 of 1 (6 items)
  • 08-01-2008 4:37 AM
    Beocenter Overature Doors
    I just got replacement glass doors for the Beocenter Overature that I'm restoring. I notice that when the doors are in closed position there is a slightly larger than normal gap that makes the unit look a bit unnatural. It gap is about 1/8th of an inch wide.
    I checked the manual online here but could not find any references to adjustments to get the doors to close closer to each other.
    Any ideas?
    Thanks!
    Derek
  • 08-01-2008 7:18 AM In reply to
    • twadle
    • Not Ranked
    • Joined on 04-16-2007
    • Berkshire, UK
    • Posts 15
    Re: Beocenter Overature Doors
    Hi Derek,
    I have completed a similar operation with a 3000. I involves removing the rear cover, locating the pully wire brackets (one top, one bottom, a tourch is helpful) and the 2 screws on eachand, I cannot stress the need to loosen these, carefully, just enough to allow the doors to be moved together and re-tightened on the 'new' wire position .The Service manual for the 3000 is available on this site.
    If you do not feel 'DIY sufficent' take to your local B&o.
    I hope this helps.
    Phil
    Thanks, Phil
  • 08-01-2008 9:58 AM In reply to
    Phil:
    Thanks for your reply. I do have the service manual from this site. Where does it explain the procedure for this adjustment?
    I know which screws you are talking about. The ones on the top rail are easier to get at. How do I adjust the bottom ones? Do I need to remove the string?
     Also do I need to make adjustments to all for brackets that hold the door in place?
    Thanks,
    Derek
  • 08-03-2008 11:27 AM In reply to
    Hi Derek,
    You need to remove the electronic pack to get at the bottom door carriage adjustment. With only 3mm or so gap I would probably leave it alone but if you feel the need then I would only adjust one door. To maintain a uniform gap it is usual to adjust top and bottom door carriers.
    On the several times that I have fitted new doors, the gap seems to be wider with the replacements doors fitted. I believe that later models of these machines have rubber buffers in the centre of the carriage slides (as do replacement slides) and new doors are manufactured to achieve a slightly wider gap to take these buffers into account. If that is not the answer, it is indeed strange that the gap grows every time I fit new doors!
    This is a bit of a balls aching job and you will probably regret starting it for the sake of a 3mm gap!!
    Regards Graham
  • 08-04-2008 5:33 PM In reply to
    Hi Graham:
    Thanks for your reply!
    Your describe my scenario precisely. I dove into it this weekend and it was an annoying process. It took me a good hour to get everything the way I wanted it!
    Derek
  • 08-05-2008 8:35 AM In reply to
    • twadle
    • Not Ranked
    • Berkshire, UK
    • Posts 15
    Hi Derek,
    Sorry for not responding sooner, I was away this weekend. I'm pleased that Graham has come to your rescue, as he helped me through my experience!
    It's a job, once mastered you never want to do again!
    Phil
    Thanks, Phil
