Latest post 06-21-2007 5:38 AM by gk31ax. 12 replies.
Page 1 of 1 (13 items)
  • 05-11-2007 4:45 AM
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    MacBook Pro / Bluetooth / audio-streaming ?
    Hi all,
    Just purchased a MacBook Pro and i was wondering if i play music wireless via Bluetooth.
    Currently, to play music wireless, i use a Sony Ericsson K800i with a wireless music receiver (MBR-100)
    to play the music from the phone through the speakers of the Beosystem 6500.
    Does the Bluetooth of the MacBook Pro support the service "Audio Streaming" ?
  • 05-11-2007 5:04 AM In reply to
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Re: MacBook Pro / Bluetooth / audio-streaming ?
    i can listen iTunes on my mobile phones bluetooth earpiece, so it must.
  • 05-11-2007 5:17 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    britops:
    Hi and thanks for your reply.
    It finds the wireless music receiver and classifies it as "headset",
    but then it displays "no supported services" ,
    whereas the K800i finds the audio receiver and displays these services:
    "Audiostreaming" and "remote control for audio"
  • 05-11-2007 7:37 AM In reply to
    • UK
    • Posts 970
    If it sees it as a headset it may require a passkey. Only guessing.
  • 05-11-2007 11:01 AM In reply to
    You will need a "Stereo Bluetooth" enable device. (A2DP).
    I googled it an it seems that Apple doesnt do that yet
    http://forums.macnn.com/90/mac-os-x/296533/os-x-a2dp-advanced-audio-distribution/
    You may want to search some more but why would you not want to use an airport express?
  • 05-11-2007 11:58 AM In reply to
    • UK
    • Posts 970
    I agree get an Airport Express, problem solved
  • 05-11-2007 1:17 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    britops:
     Passkey was entered and accepted.
  • 05-11-2007 1:20 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    britops:
    Yes, i will get an Airport Express, eventually.
    For the moment, the new MacBook Pro and the recent B&O purchases have depleted my savings Smile
  • 05-11-2007 1:23 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    jk1002:
    Thanks.
    Interesting, i'll dig deeper into that.
  • 05-11-2007 1:59 PM In reply to
    I am waiting for Leopard - and getting bored doing so!!
  • 05-11-2007 2:05 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Peter:
    And this "Leopard", does this support audio-streaming, like mentioned above ?
  • 06-07-2007 4:25 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    britops:
    AirPort Express & Monster-cables were delivered today Smile
    Very easy to install /setup.
    iTunes is now playing through BeoSystem 6500 Smile
    Next step is to learn the Apple Remote codes into the Lintronic converter
    so that i can control iTunes by Beo4.
    I have to say that so far, i'm enjoying the swith to Mac,
    and i ask myself why i didn't make the swith earlier !
    Thanks for the advise regarding AirPort Express Smile
  • 06-21-2007 5:38 AM In reply to
    Ignace:
    Peter:
    probably and time travel as well Laughing
