1st March February 2012
Latest post 11-30-2008 9:12 AM by Beobuddy. 37 replies.
07-31-2008 6:06 PM
david707
- Joined on 04-20-2007
- Posts 295
Re: Picture mute on Avant
I spoke too soon! My Avant (MK2) will not mute the picture using source>list>AV>source as described in other threads. Is there no way to switch off the picture on this version?
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
David, the only way I have ever been able to mute the picture on my Avant (32 vhs) when wanting to listen to a sound source is by doing this. Whilst watching TV or Sat, switch off, then while it is parking itself, quickly press AV, Radio, CD, Phono or A Tape. I'm sure this is not the way it is supposed to work, but it works for me. Andy T.
frankmj
- Joined on 04-18-2007
- Denmark
- Posts 177
Try to put the Avant in V.OPTION 2. Then the sequence source>list>AV>source should work. /Frank
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
Add P.Mute to the List of Beo4 Edit Sorry didn't read it all... But option 2 and then AV + source will work
harrykym
- Joined on 08-04-2008
- Rossendale
- Posts 86
what is picture mute? james
BS-3, BS-1, BS-OVERTURE, AVANT-28"RF, AVANT-28" DVD, AVANT 32" RF, 3xBEO-4, LC-1, 4xBEOCOM-6000, BEOCOM-2, A9 KEYRING, DVD1, Beosystem 10, BEOCOM 3, BEOLAB 2500, BEOSOUND CENTURY, BEOLIT 707
harrykym
- Rossendale
- Posts 86
that's a usefull feature, can you do it whilst using the camcorder input? i have my beosound 1 connected to the avant via this james
david707
- Posts 295
Frank, My Avant picture mute works in V.Option 2. For e.g TV>list>AV>TV. The picture mutes followed about one minute later by the motor stand returning to the standby position and the tube turning off. I have an unconnected BC9500 in the room which switches on to Aux when I do this. Is there another option to mute the picture without affecting the BC9500? Thanks for the help David.
BMGHB
- Joined on 05-12-2007
- Posts 219
No. It's actually A-V.AUX. Its in the list if you add it.
BeoVision10-46MKII,BL3,BL2,BS8,Beo5
frankmj
- Denmark
- Posts 177
Sorry for my misspelling  /Frank
frankmj
- Denmark
- Posts 177
david707: Frank, My Avant picture mute works in V.Option 2. For e.g TV>list>AV>TV. The picture mutes followed about one minute later by the motor stand returning to the standby position and the tube turning off. I have an unconnected BC9500 in the room which switches on to Aux when I do this. Is there another option to mute the picture without affecting the BC9500? Thanks for the help David.
Put the BC9500 in A.OPTION 1, then it shouldn't listen to video commands. /Frank
david707
- Posts 295
frankmj: david707:
The 9500 still opens the Aux port using A.option 1 and V.option 2 at the same time as picture mute. This is OK unless I want to mute the TV sound and listen to the radio. It then becomes a problem because volume and muting is simultaneous on the 9500 and Avant. I assume that something so simple with the LX (picture>mute) is rather more difficult to achieve with the Avant Mk2. Maybe earlier Avants were not like this? David
frankmj
- Denmark
- Posts 177
Then you have 2 options. Buy a MCL converter to connect BC9500 and the Avant, or put the BC9500 in option 4. Then you have to use LINK->source to operate the BC9500. /Frank
david707
- Posts 295
Thanks for the help. David
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
The Stig - ver. 1.7: Add P.Mute to the List of Beo4 Edit Sorry didn't read it all... But option 2 and then AV + source will work
You mention adding P. Mute to the Beo 4. I do not see that on my Beo 4 as a possible button to add nor is it listed in the Beo 4 guide on the B and O site. Is that a recent addition to the Beo 4? If P. Mute is added will it work with a BV7-40MKIII? Thanks
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Quim43
- Joined on 11-15-2007
- Tarragona (Catalonia)
- Posts 1,030
Hi Razlaw My Beo4 is not new at all, and P.Mute can be added in the functions list. You have to press Standby+List at the same time. You will see Add? in the screen. Press Go and List till P.Mute appears in the screen. Press Go and P.Mute function will be added in your Beo4. And yes, P.Mute works with a BV7 Mk3. Cheers
Razlaw
- Illinois
- Posts 1,770
Thanks! I guess I will need to order a new Beo 4 as our newest one (we have three) does not have the P. Mute function. I have gone through the entire list of functions that can be added and it is not there.
Razlaw
- Illinois
- Posts 1,770
Just tested one of the older ones, not there either.
Beobuddy
- Posts 1,582
Sorry folks, but what a load of rubbish am I reading! Don't know where to start but I'll give it a start. First of all, how are the avant and the bc9500 connected? How/where are the speakers connected? On the avant? Are they not, then both are in option 1 and do not set the avant in option 2 and the bc9500 in option 1, That will give you problems when using track, volume etc. If you want the Avant to be the master in the system, the BC9500 has to be connected through a ML/MCL converter and the speakers (if there are speakers) has to the connected to the sound board on the avant. Only then the avant needs to be in option 2. If there isn't an surround board in the avant, or extra frontspeakers are available, it will also work. With the above mentioned setup the avant is the master and the BC9500 the slave. If you're watching TV/Sat, DVD or ..just press Radio/Cd without the AV instruction. The avant automatilcally turns off. It knows it´s not needed anymore. Only the speakers will remain on. Only if you´re watching TV/Sat and want to mute the picture but still listen to sound of it, then you press AV followed by the videosource. But there is a difference between switching to AV-videosource while you´re watching already or when the set starts from standby. Pressing AV-Source while watching gives you 3-stereo if you have speakers attached to the avant. Starting from standby and pressing AV-videosource will result in only 2-stereo. If there are speakers attached, then the speakers are used, otherwise the avant speakers are used. If you want to listen to the radio while watching tv/sat then you have to use AV-radio/cd etc. If the avant and the BC are not connected to each other, both has to be in option 1, and the tv has to be turned off manually. My first avant I owned was in the beginning from 1995 and still own an avant,the 32 RF DVD type. The function P.Mute on the Beo4 will not work on an Avant.
david707
- Posts 295
Both are in option 1 because they are unconnected. A-V.AUX or source>AV>source will mute the picture but only when the Avant is in option 2. This is not ideal because as you say volume/standby etc is not independent but it does work. If the Avant would respond to picture>mute (as the LX etc) or p.mute (BV7 etc) there would be no issue. Unusual for a B&O product? Thanks for the reply David
k984942
- Joined on 11-10-2008
- London, UK
- Posts 194
Hi Keith Can you suggest the best way to attach an ipod to an Avant and have it play through the speakers without the screen being on? Thanks
32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
k984942
- London, UK
- Posts 194
In fact, can anyone help?!
