Latest post 08-14-2008 7:04 AM by Peter. 25 replies.
Page 2 of 2 (26 items) < Previous 1 2
  • 08-14-2008 7:04 AM In reply to
    Re: CD4 Modulator
    No you can't. The Beomaster 6000 however has an input for the 4 channel record player but the Aux socket is switchable so that you can use a stereo record player. This input has a switchable RIAA built in.The BM3400 has a similar set up though one swaps between the two inputs using a button under one of the sliding lids.
    If you are using a Beogram 6000 with other Beomasters, you use either the Aux or Tape input.
