Latest post 09-02-2008 8:12 PM by StrangeSteve. 2 replies.
Page 1 of 1 (3 items)
  • 07-30-2008 8:48 AM
    Beomaster 3300
    It was my intention to write a quick post about my beomaster 3300, another relic that has not been used for a while. Having just redecorated the conservatory i have decided to give it the retro look !!!.
    I recently accquired a Beocord 3300 , got the Beomaster out and low and behold it worked. The Beomaster had developed a fault whereby  it started buzzing, particularly on the tuner and would drift and you would get slightly different levels of hum depending on what mode you had selected. I thought this might be some leaky capacitors in the power supply or the amp stage, no doubt it if is, it will fail again in a couple of hours.
    The Beocord all seems to work fine apart from it appears to be running a little fast ( well at least Christy Moor never sounded like that when I saw him live)
    Is there a pot to control the motor speed ?
    Steve
  • 08-30-2008 5:00 AM In reply to
    • Mohawk
    • Top 500 Contributor
    • Joined on 01-30-2008
    • Sweden
    • Posts 103
    • Gold Member
    Re: Beomaster 3300
    Hi Steve
    Yes there is a pot to adjust the speed on the bc3300. The pot is located on top of the drive motor.
    /Fredrik
  • 09-02-2008 8:12 PM In reply to
    Re: Beomaster 3300
    Hi Fredrik,
    Thanks for the reply, i thought as much. I will have a tweak.
    All the Best
    Steve
