Latest post 07-30-2008 11:37 AM by Craig. 6 replies.
Page 1 of 1 (7 items)
  • 07-30-2008 6:30 AM
    Scart expander for B&O TVs
    Hi all:
    I have a Beovision 1 which I would like to connect my PC TV out to (via scart), My Laserdisc player (via scart) and my Xbox 360 (via scart). There are not enough ports. Thus I would like to buy a scart expander for the connection of my current equipment and any other stuff I may buy. I bought a rubbish one from £1 world but obviously it didn't work. Thus is there one that people reccomend, or does it have to be a B&O one and if so what is its name etc.
     Also, is there a suitable scart configuration that I can program so that all equipment works properly? It is all non B&O?
    Graham
  • 07-30-2008 6:50 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Scart expander for B&O TVs
    hi
    seen something which might work on the maplin(.co.uk or.com) site about £30 but it has an amp built in to prevent signal losses also i recall a similar piece which had a remote to select or more recently an auto one - if near an outlet you can buy, try and return if no good!
    might be worth a look!
    salut a la france
    tony s
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 07-30-2008 9:06 AM In reply to
    Hi:
    Thanks, that makes sense - I should have said that the £1 world one produced sound but no picture and that it has been discussed before that the Beovison 1 is a little "special" with regards to connections. I am wondering if the scarts need to be programmed on the menu to accept the sources that I am trying to put through it?
    I have the manuals but can't make sense of it - intuitive my ****!
  • 07-30-2008 10:34 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Graham, maybe you need to use an AV2 expander. This was made by B&O so should do what you want.
    CraigSmile
  • 07-30-2008 11:05 AM In reply to
    Thanks, are these available from Lifestyle AV or schemeBay or B&O - I have never seen one before.
    Graham
  • 07-30-2008 11:33 AM In reply to
    • Craig
    • Posts 4,855
    Not seen many on Ebay, I would give Lee a call to see if he has one.
    CraigSmile
  • 07-30-2008 11:37 AM In reply to
    • Craig
    • Posts 4,855
    Graham, here is a link.
    AV2 Expander
    CraigSmile
