Latest post 12-14-2008 8:05 AM by TEL. 5 replies.
Page 1 of 1 (6 items)
  • 07-29-2008 1:32 PM
    • djram
    • Not Ranked
    • Joined on 08-26-2007
    • Posts 78
    • Gold Member
    VX Sensor
    Today I bought a Beocord VX 4500 at a flee market for only 6 Euro. Nice exterior condition and to my supprice the unit seems to work, the sound is really good an the picture quality i quite ok. However, I can not control it by remote control. It is hooked up to my LX2500 (my only TV-set) and probably the datalink module II was not installed. Strange because it should have some kind of datalink since I can control the TV from the mcl2a in another room via the beomaster 5500 in the main room. If I press V.tape in the the link room, the vx 4500 starts but the TV does not. If I press TV, the TV starts too. As I see it, I need a vx sensor.
    Does anyone have a spare VX Sensor for sale?!
  • 07-29-2008 2:38 PM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: VX Sensor
    this is what the PCG software displays regarding Datalink.
    ************************* VIDEO SYSTEM SETUP **************************
    Beovision LX 2500
    Beocord VX 4500 (VR 1)
    Connection Video
    Connect the VR 1 to the TV-set using a fully specified 21/21-pin
    A/V cable (RGB cable).
    Selecting option on the TV-set
    The TV-set must be equipped with a Datalink module MK2.
    If a Datalink module MK1 is built into the TV-set, replace
    the 5IC1 software with the MK2 version, part no. 8341101.
    Option:  OPTION 1 (Factory setting)
    Set the five code switches on the Datalink module to the following
    positions:
    Switch 1 - OFF
    Switch 2 - OFF
    Switch 3 - OFF
    Switch 4 - OFF
    Switch 5 - OFF
    If no Datalink module is built in, modify the TV-set as follows.
    NEW 26/27IC4            8341001
    NEW Tuner Module        8003904 (module 51 38XX)
    IF  Sound Module        8003889
    if Nicam, NO modification
    if Sound Module 24/28 ver. II, remove IC 103,
    establish clock/data signal path as in module 55/56 38XX
    if Sound Module 24/28 ver. I, shift to Nicam or module 55/56 38XX
    The TV-set has now been modified to type 38XX.
    Make now a new configuration with a 38XX (LX2502/2802) TV-set
    Note!
    The TV must be equipped with a Teletext module.
    ************************* AUDIO SYSTEM SETUP **************************
    Beosystem 5500
    Beovox passive
    Connection Audio
    Connect the Beovox to the SPEAKERS 1 socket on the audio
    master using a loudspeaker cable.
    Connect the aerial to the aerial input of the audio master.
    Selecting option on the audio master
    Option: OPTION 1.5
    Press:  STAND-BY   SOUND 1 STORE
                       SOUND 5 STORE
    ********************* AUDIO/VIDEO/LINK SYSTEM SETUP *******************
    To obtain A/V intergration between these products the audio master
    must be equipped with a Beolink software, part no. 8341051.
    If the audio master is equipped with a Beolink software, it is
    indicated by a sticker marked BEOLINK on the rear panel.
    The TV-set must be equipped with a Datalink module, part no.
    8003780. If the TV-set is equipped with a Datalink module, it
    is indicated by a sticker marked DATALINK on the rear panel.
  • 07-29-2008 2:43 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: VX Sensor
    Piece of cake then,ErmHmm
    Poor me, never win owt!
  • 07-29-2008 3:30 PM In reply to
    • djram
    • Not Ranked
    • Posts 78
    • Gold Member
    Re: VX Sensor
    Yes indeed.
    Thank you Ignace, for checking the PCG.
    There is no datalink sticker on the TV-set, it is a type 3442 and the whiteline edition. For me, it would be to advanced to update the set to datalink mk 2 as stated in the PCG printout.
  • 12-14-2008 8:02 AM In reply to
    • TEL
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Berks U K
    • Posts 92
    Re: VX Sensor
    See below
    TEL
  • 12-14-2008 8:05 AM In reply to
    • TEL
    • Berks U K
    • Posts 92
    Re: VX Sensor
    I have a VX5000 which I want to connect to Beovision 7-40, but find I'm unable to display the VX5000 menu's etc. all it will do is play or stop (and standby).
    I'm told a VX sensor is the answer, any idea how much these are or does anybody have one for sale?
    TEL
