1st March February 2012
Latest post 07-30-2008 4:44 AM by PhilLondon. 7 replies.
07-28-2008 8:05 AM
Ehlerz
- Joined on 04-17-2007
- DK
- Posts 510
Hi all, just want to share this with everyone. The danish company Lauritz Knudsen just made a new lightdimmer for mounting directly in your existing outtake. The dimmer works by touch AND...."Drumroll" .....Beo4 and Beo5. Have a look. http://shop.oneremote.dk/catalog/product_info.php?cPath=70_71&products_id=2507&language=en Dont know about you but i love it :-) Thought you should know /Ehlerz
BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
Karel Uyttendaele
- Joined on 05-19-2007
- Aalst, Belgium
- Posts 682
Re: New lightdimmer from LK.
Mmm.. looks very interesting... I'm not looking for an extra dimmer at the moment... So someone else will have to take the plunge and test it out.. Karel
The race for quality has no finish line- so technically, it's more like a death march.
EOB
- Joined on 04-18-2007
- Posts 188
Does this mean that you can just plug it in the wall socket and use the regurlar wires already there ?. Apose to Bang olufsen LC2 where you had to draw extra F and neutral wires to the sockets ?
Ehlerz
- DK
- Posts 510
Hi EOB Certainly seems lige it. I am not an electrician, however a guy at Oneremote provided me with a detailed mountinginstruction. http://shop.oneremote.dk/content/43350_org_manual.pdf its in danish, but the drawings could maybe provide the answer. Here in denmark, it should be an out of the box solution without having to do aditional wireing Maybe somone with a little more knowledge kan confirm??
Soren
- Joined on 05-04-2007
- Kolding Denmark
- Posts 56
It is correct you can use Beo4, but I think the funtions are to limited compared to LC1 and LC2, it is only possible to use Light RED, YELLOW BLUE and GREEN. that means 4 dimmers total. Soren
Ehlerz
- DK
- Posts 510
Soren: It is correct you can use Beo4, but I think the funtions are to limited compared to LC1 and LC2, it is only possible to use Light RED, YELLOW BLUE and GREEN. that means 4 dimmers total. Soren
Hi Soren I think you are right about the 4 available controls. However, who has more than 4 wallmounted lightdimmers in each room? I indeed do not. If you do however, maybe it is not a suitable solution as Soren describes.
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
That also mean you cannot mix LC2 and this new lightdimmers in the same room, unlike with the INNOVUS.
Page 1 of 1 (8 items)
