Latest post 07-28-2008 9:47 AM by joeyboygolf. 3 replies.
Page 1 of 1 (4 items)
  • 07-28-2008 6:22 AM
    Beoloab 2500 front covers
    To protect the speakers from [pressing and fiddling] little children's hands : is it possible to replace the cloth version front covers by the alu version on the Beolab2500 speakers without any adjustments ?
    Leon: Beoworld's First "First Prize" winner. "Carpe Diem et Dolce Far Niente"
  • 07-28-2008 6:52 AM In reply to
    • Foxtrott
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Vienna, Austria
    • Posts 500
    Re: Beoloab 2500 front covers
    Hi Beologisch
    Short answer: No. Sad
    To fit the alu-covers you need to replace the part of the BL2500 where the speaker units are mounted as the alu-fronts have a different mounting system. You'd need the "baffle kit" for the BL2500 but I don't know if it's still available as spare part.
    cheers
    Foxtrott
    "The first thing we do, let's kill all the lawyers."
    Henry VI, Part 2 William Shakespeare
  • 07-28-2008 7:24 AM In reply to
    Hi Foxtrott,
    thnx for the speedy reply !
    a pity it won't work.
    I'm gonna try to find 2 "baffle kits" [plus alu covers] and "quanta costa" offcourse....Wink
  • 07-28-2008 9:47 AM In reply to
    I priced this conversion the other day for a customer. Still available and £186 for parts in the UK.
    Be aware that the Al fronts are very delicate and any dents stick out like a sore thumb!
    If I were you I would buy one of the wall brackets that I have for sale and mount the whole lot out of the childs way!!
    Regards Graham
