Latest post 05-12-2007 3:28 AM by Peter. 11 replies.
Page 1 of 1 (12 items)
  • 05-10-2007 5:29 PM
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    TEXT on Beovision with SKY problem
    If I watch Bravo channel on SKY then switch to BBC1 Teletext appears for about 2 seconds. Other channels do it too. It happens on both my Avant & BV1. I remember something about this on the old forum can anyone remind me of the outcome.
  • 05-11-2007 6:34 AM In reply to
    • UK
    • Posts 970
    Indifferent [:|] Re: TEXT on Beovision with SKY problem
    I'm not alone with this problem. Am I?
  • 05-11-2007 6:49 AM In reply to
    Never noticed it! And I have a similar set up.
  • 05-11-2007 6:54 AM In reply to
    • UK
    • Posts 970
    Oh dear, Thanks Peter can you do a simple test, go to channel 121 then 101 and see if it happens. It does it every time for me. I see BBC Ceefax for a second then it dissapears. I'll turn everything off and back on again to see if that works. Can you remember a topic on the old forum about this?
  • 05-11-2007 8:10 AM In reply to
    I do have vague memories. I will do it tonight. I am on call so will be a bit late.
  • 05-11-2007 8:42 AM In reply to
    If I remember it correctly the issue was with subtitles apearing on channels 121-125 and not teletext as a whole.
  • 05-11-2007 9:35 AM In reply to
    • UK
    • Posts 970
    Your correct. It happens on channels
    121 - Bravo,
    122 - Bravo+1,
    123 - Bravo 2.
    Then when you leave these channels and go to BBC 1 it happens on this channel too. I dont watch Bravo often.
  • 05-11-2007 3:28 PM In reply to
    Quite correct! It does it on mine as well! Not on my AV9000 - but I don't have the STB-C fitted yet!
  • 05-11-2007 6:41 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    It doesn't happen to mine. I have Avant 32 VCR and Sky plus.
    Andy T.
    Poor me, never win owt!
  • 05-12-2007 3:00 AM In reply to
    Mine is an Avant 32 DVD and Sky+. You only get a small flash of Teletext - less than half a second.
  • 05-12-2007 3:13 AM In reply to
    • UK
    • Posts 970
    Thanks for testing. What do you think is going on?
  • 05-12-2007 3:28 AM In reply to
    Logically it has to be something in the STB-C that is sending the Text instruction before changing channel. Why - goodness knows!
