Latest post 01-23-2012 3:10 PM by Leslie. 3 replies.
Page 1 of 1 (4 items)
  • 07-24-2008 7:22 PM
    • lampy
    • Not Ranked
    • Joined on 02-11-2008
    • Posts 6
    beolab 3000/5000 panel speaker amplifier
    hi,
    can anyone help me with a problem regarding the amplifier section of the above speakers?
    the fault lies in pcb board 8001032 as i have exchanged this board out of another working speaker and it has rectified the fault.
    the fault is that the relay does not click in when the speaker is sent a signal from the beomaster, no sound or display is shown, only the red standby pilot lamp is lit. there is a IC chip on board 8001032 ( IC 301)  i have replaced this with a new one, but it has made no difference.
    can anyone help me locate circuit board 8001032, or help me locate the fault on it?
    thanks,
    lampy.
  • 07-25-2008 2:13 AM In reply to
    Re: beolab 3000/5000 panel speaker amplifier
    I suggest you contact Tim Jarman via www.beocentral.com who will be able to help you.
    Regards Graham
  • 01-23-2012 2:57 PM In reply to
    • Abou58
    • Not Ranked
    • Joined on 08-06-2009
    • Posts 5
    Hello, I've exactly the same problem you described. Have you resolve it and how ? Thanks. H.J.
  • 01-23-2012 3:10 PM In reply to
    You could ask Ipaul, member of this forum. He's a genius, repaired my Beolab 3000 amp.
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
