This may well be a long thread but I hope at the end of it, I will have a working unit and an A-Z of fault finding & repairing one of these will exist for others to read.
From the beginning, I got this deck in an unknown state clearly not working due to no tacho and no cartridge. These along with the service manual have been obtained and all the electrolytic caps have been replaced except the big 2200uF 40V one which tests OK (waiting for a new one)  and the non electrolytic in the transformer case which measures exactly 39uF.
Usually at this stage I understand the machine would often work if the gremlins had not got at it. Not this one!
Switching on (without the cartridge in place to protect it) a red dot appears in the  display. Pressing 'turn' makes the deck go round, either of the speed selectors works the display changes 33/45  and the turntable rotates  accordingly. Pressing 'play' the arms move, I can see a red dot on the end of the detector arm whilst it is moving and there is a light shining under the detector arm. It does not make it to the record, it just stops by the end of the 'stick on' aluminium surround but the turntable keeps rotating. The 'stop' button does not seem to do anything nor any of the other buttons in this condition.
Any clues on where to look from here would help.
Q1 what makes the pickup arm raise & lower? there is nothing obvious on this one..
Q2 If it was working correctly and there was no record, what happens when 'play' is pressed? would the detector keep going until it got to the centre then return & switch off?. presumably this is how it would find a 7" record? by seeking it??
Thanks for your help
