Latest post 07-24-2008 4:07 AM by hulpaub. 19 replies.
Page 1 of 1 (20 items)
  • 07-23-2008 2:21 PM
    HELP ME!
    I opened the up side of the dvd player of a bang & olufsen tv and it doesnt close i did it with my hand and i might have to pay for it and work FOR 3 YEARS to pay it off!!!
    How do i close it????IT doesnt  close with my hand.!!!
  • 07-23-2008 2:25 PM In reply to
    Re: HELP ME!
    pleaseeeeeeeeeeeeee
  • 07-23-2008 2:31 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: HELP ME!
    Which model TV?
    How did you open it?
    Try pressing DVD on the remote.
    Poor me, never win owt!
  • 07-23-2008 2:36 PM In reply to
    Re: HELP ME!
    Its a silver dvd 2
    The tv i dont know but it is a black one that turns when you switch the tv on
  • 07-23-2008 2:40 PM In reply to
    Re: HELP ME!
    Its a silver dvd2 and a black bang & olufsen tv both bang & olufsen dont know the model pressing dvd didnt work
  • 07-23-2008 2:47 PM In reply to
    Re: HELP ME!
    Still not completely clear - which bit is not working - the DVD2 or the TV? The DVD2 doesn't open automatically and has to be closed manually. Is actually a Philips. B&O equipment usually has fail safe mechanisms for the lids so don't panic! I guess you are house sitting someone's system! If yours, I would suggest a few things but the best thing to do if not yours is leave well alone - the owner will probably know how to fix it - you run the risk of making it worse.
  • 07-23-2008 2:54 PM In reply to
    • Jandyt
    • Posts 13,004
    Re: HELP ME!
    Sounds like an Avant and a DVD2. I am not familiar with the DVD2, but someone will surely be along shortly.
    Edit... Sorry Peter, I posted before reading your reply.
  • 07-23-2008 3:09 PM In reply to
    Re: HELP ME!
    The dvd isnt working i pulled it open but nothing appears to be broken it just doesnt close im talking about dvd2
  • 07-23-2008 3:18 PM In reply to
    Re: HELP ME!
    it isnt mine but i do not want them to find out
  • 07-23-2008 3:20 PM In reply to
    • Jandyt
    • Posts 13,004
    Re: HELP ME!
    Is the DVD jammed in the tray?
  • 07-23-2008 3:25 PM In reply to
    Re: HELP ME!
    I dont know what you mean exactly but it isnt blocked in the panel?
    I guess .
    Look: I will explain:
    Its a dvd 2 and we wanted to watch a movie with it so i pulled the above part down and we watched, and now it doesnt close anymore
  • 07-23-2008 3:26 PM In reply to
    Re: HELP ME!
    The WHOLE above panel everything works but the silver doesnt close
  • 07-23-2008 3:27 PM In reply to
    Re: HELP ME!
    Is this the model you mean?
  • 07-23-2008 3:28 PM In reply to
    Re: HELP ME!
    Yes
  • 07-23-2008 3:31 PM In reply to
    Re: HELP ME!
    It should just push up. Did you hear anything snap when you opened it?
  • 07-23-2008 3:32 PM In reply to
    Re: HELP ME!
    No it didnt snap i think and it doesnt look broken just if i push it up it goes down again
  • 07-23-2008 3:37 PM In reply to
    • Dude1
    • Top 500 Contributor
    • Joined on 09-18-2007
    • London
    • Posts 189
    Re: HELP ME!
    This is a common fault.
    Check if the little plastic arm has come off the face plate.
    Dont panic. Dont open it up. It may be a warranty issue.
  • 07-23-2008 3:38 PM In reply to
    Re: HELP ME!
    Try pushing it in towards the tray. Try one side then the other. I wouldn't worry - It doesn't sound broken.
  • 07-23-2008 3:43 PM In reply to
    Re: HELP ME!
    I don't have/have not used the DVD2. However, check the basics. Have you pulled the power cable out of the back? Push it to see if it goes back in. This might be your problem - check the basics first.
  • 07-24-2008 4:07 AM In reply to
    Re: HELP ME!
    IM going to the b&o shop today to get it fixed thanks all for your great help
