I have a problem with my BeoPort. I'm using iTunes 7.7 (43) and OSX 10.4.11 and BM-Link 1.5 and firmware 1.31.
The problem is that BM-Link shuts down after a minute or so. The remote doesn't function either. I've tried to install the older version after uninstalling the new one, without any luck.
Any ideas?
Same happend to me with the 1.5 version.
I removed the 1.5 version and installed the older version.
Now it's up and running and keeps on going.
setup: PowerBook G4, Mac Mini (stone age, no IR sensor), BV7-32 (stone age), SW 10.4.11
THANX!
I've tried to do the same, but I can't download, the old version...
- I'll try and contact Anders Odlund, to see if he can send the file to me.
I tried it, and had succes.
Maybe you have your computer in private mode ?
If so all downloaded files disappear from the download center.
Oh, and the files are only for MAC.
