Latest post 07-25-2008 6:26 AM by soundproof. 6 replies.
Page 1 of 1 (7 items)
  • 07-21-2008 10:49 PM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    a little help regarding incorporating a mac mini into b&o
    I have a 9k as an audio master and a bs3 as a video master; i have a beoport which I'll connect to the mini; I also have a BL3500 in a link room as well as a BC2 with BL3s in another link room
    How can I connect all of these things with the mac?
    I'm sure I'll need Anders program. . . will that give me control of N.Music and N.Radio in Link rooms?  via Beo4 or the iTunes Remote app?
    Also, will the BC2 display the information of the Artist, etc.?
    Lastly, I"m also getting an Apple TV which I'll use as a V.Mem2 or some other source I presume. .
    Any thoughts??
    MJM
    I'm ready for something new that I actually want to buy!
  • 07-22-2008 2:18 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: a little help regarding incorporating a mac mini into b&o
    Yes, you are correct in everything you've said. Just whack the BeoPort into one of the USBs on your MacMini, install Anders' software and you can control iTunes with your Beo4 from anywhere in the link system.
    If you want to take things a step further, you can get an iPod Touch or iPhone and use Apple's Remote app (get it through the iTunes Store) to control iTunes via WiFi. The BeoCenter 2 or BeoLab 3500 will still display artist information!
     Weekly top artists:
  • 07-22-2008 12:42 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    I actually got a "free" iPod Touch when I bought the mac mini.  I plan to use that remote function. . .
    Will keep you posted
    They just arrived via FedEx so hopefully can hook them up tonight. . .
  • 07-23-2008 5:17 PM In reply to
    You'll need an audio cable running from the Mac Mini to your TV.
    But why don't you use the DVI option as well. Feed the DVI cable also in the TV and you can control iTunes on screen.
    I've this setup and DVDpedia software for watching stored DVD's.
  • 07-24-2008 4:32 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Tell me more about this DVDPedia software. . .
    I'm intrigued and would like to know more about it. . .
    Any place I can download it??
  • 07-25-2008 4:57 AM In reply to
    • francis
    • Top 500 Contributor
    • Münster, Germany
    • Posts 108
    Google is your friend.......
    link
    |BV 7-32|BL 7-1|Ouverture|BL Penta|BL 6000|BL 2000|Beocom 6000|Beotalk 1200|MX 4000|Beoport|Beo4|Beo5|A8|A9|
  • 07-25-2008 6:26 AM In reply to
    And the search function here is quite fancy, too.
    http://forum.beoworld.org/forums/thread/56821.aspx
