Latest post 07-22-2008 2:51 AM by halid. 4 replies.
Page 1 of 1 (5 items)
  • 07-21-2008 5:46 PM
    Powercords
    Hi, I am building a sort of hidden box in the wall that will connect all my devices to my BV 7-40 and 7-32. The original powercords will be too short and I was wondering if it will affect the picture quality, or affect something else, if I get longer cords ? I think ( but I can be wrong ) that I read something about this in a manual to my BS 2500 for many years ago, that B&O recommended to use the original cord.
    If I get longer cords, is there anything special that I should look for when I buy them like isolation, thickness and so on ?
    Best regards
    Hans
  • 07-21-2008 5:49 PM In reply to
    Re: Powercords
    As long as you by cable that is up to the job, it will be fine. By that I mean decent plugs and the right rating. I am afraid I do not believe in audiophile power cables any more than I do the tooth fairy.
  • 07-21-2008 5:54 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Powercords
    The whole 'power cable' thing is one of the biggest hifi myths around. My thinking is just go with a good quality, but basic cable with good terminations. It'll last a lot longer, a little quality goes a long way.
     Weekly top artists:
  • 07-21-2008 8:03 PM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Re: Powercords
    Hallo Hans;
    The powercords can be as long as you make them. Just shield  the cords accordingly, from other cables and cords to avoid interference and if AV from ghosts and TI.
    I have 20 M data, AV, amd ML cords running thoughout the house with never a problem experienced..
  • 07-22-2008 2:51 AM In reply to
    Re: Powercords
    Thanks everyone, I will get new cords immediately.
    Best regards
    Hans
