Hi James,
when I did my repair I used dry wall plaster board plugs (the grey ones) and cut off the 2 "arrow head" type prongs. I drilled holes in the speaker cover points where the original locating pins were and piloted some screws into them before unscrewing them and cutting off the heads. Next I glued the blunt ends of the screws with epoxy resin into the plaster board plugs. When they had set I then simply screwed them into the pre - drilled holes in the frets also fixing them with epoxy resin, they were a perfect fit and a bit of black paint finished them off nicely
I hope my description makes sense as some photo's would have helped here but these speakers are long gone from my possession.
Chris.
