Latest post 08-06-2008 12:04 PM by Vandelay. 17 replies.
Page 1 of 1 (18 items)
  • 07-18-2008 12:53 PM
    Beocenter 9000 and cd-r/rw
    Hello everyone! I´m thinking of buying this 9000
    that I have had my eyes on for a long time. Only thing I´m wondering is that does it play burned cd´s (cd-r and cd-rw)? The technology is pretty old so I think not, but I´m optismistic
  • 07-18-2008 12:58 PM In reply to
    Re: Beocenter 9000 and cd-r/rw
    my 9300 plays them fine, though it is newer than the 9000...
    anyone else?
    ++++edit++++
    quick note: there has been some discussion on here recently re: the devaluation of the 9000 primarily because of failure w/ the cd unit, esp the clamping device. apparently parts are scarce or perhaps impossible to find unless someone is parting a working one out. if you like the style of the 9x00 series, you may want to consider the newer 9300. i *believe* that the cd parts for them are more readily available. certainly some parts are still stocked by b&o -as i have bought parts for mine within the last year direct from them.
    ++++edit++++
    • B&o bottle opener
  • 07-18-2008 1:13 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    What I found when I had a Beocenter 900 was. It would play most, but not all brands of CD-R. As for CD-RW it would not play them at all. Hope this helps.
    CraigSmile
  • 07-22-2008 1:04 PM In reply to
    Thanks a lot! This was very helpfull. 9300 would be nice if one of those would be available somewhere. I really like the style.
  • 07-22-2008 5:43 PM In reply to
    On the subject of the 9000 CD mechanism, has anyone tried a Naim like puck in a broken one?
  • 07-27-2008 7:07 AM In reply to
    Yep. I just bought the bc9000 system. Thats my first B&O product. Hope that the cd will stay in working order. I got the white cx100 speakers  on the side as a freebie. Do you have any opinions about them?
  • 07-27-2008 8:48 AM In reply to
    They probably have foam rot. Take the frets off the woofers and you will see what I mean.
    Regards Graham
  • 07-27-2008 1:32 PM In reply to
    • Craig
    • Posts 4,855
    Vandelay:
    When I had a pair of CX100's with my Beocenter 9000 I always found them to be lacking in Bass. What I would recomend is getting a Beovox Cona also.
    CraigSmile
  • 07-29-2008 6:00 PM In reply to
    B.t.w. it plays all kinds of burned discs. Amazing! Sometimes I just have to skip the first track.
    The speakers lack alot of bass at the moment because the foam speaker surrounds are all broken (almost turned to dust). I guess those arent ment to survive time. I have to find someone to repair them. And if I happen to find a Cona in good condition, I will buy it. Thanks for the tip!
  • 07-29-2008 6:56 PM In reply to
    Hi there
     The rubber surrounds do that, which is very annoying, but there are 2 ways to cure the problem.
    Firstly you buy new drive units from B&O. easily fitted yourself, or they can do it for you.
    Or you can refoam them yourself. The foams are available cheaply on eBay, and easily fitted with some latex adhesive. By far the worst bit is removing all the old foam.  It goes like tar and is a messy stuff indeed. Other than that, the job is easy Smile
    And yes, CX100s, are a bit bass-light, the CX50's I have are even moreso...
    Ray
    Я люблю Банг и Oлуфсен
  • 07-31-2008 4:51 AM In reply to
    I bet these ones will come off mostly by using vacuum cleaner, but I`m not sure if I`m handy enough to fit the new surroundings to the speakers. Do you have info how much the new drive units from b&o would cost?
  • 07-31-2008 7:15 AM In reply to
    Yes, most of it comes off easily and cleanly, but the edges where it was glued to the diaphragm and the basket will most likely be very sticky and messy indeed, and the only real way to remove it from the diaphragm edge is to roll it off with your thumb. It is actually quite easy to do, but if you are thinking of going to the dealer, I've been advised by a fellow Beoworlder that replacement woofers are £25 each, which isn't bad at all. I must emphasise though that is only what I've been told - I've not yet checked myself...
     Hope you get them sorted.
    Ray
  • 07-31-2008 3:09 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    hi there
    i have just recently repaired(refoamed) some penta driver units - mine were all sticky gooey etc - got it off the frame using a chisel ended screwdriver just scraping away when as much as possible removed i used cotton wooln buds soaked in meths - a messy process but it cleaned the base back perfectly#
    the cone edge was also cleaned using meths applied with an artist sized paintbrush - the goo softened up then a blunt stanley or smaller craft knife was used to slice the goo off the the area was again treated with meths and the unsharpened edge was run round at 90degree to the cone to scrpae off the rest again the cone was final cleaned with meths on a cotton bud - the unit was then left for 24 hours for the meths to evaporate off - the refoam described elsewhere was then completed - i did the cone first then the outer rim with grear success - hope this helps!
    salut a la france
    tony s
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 08-04-2008 3:38 PM In reply to
    Thanks!  I think I will change the foams myself encouraged by these tips.
    The white paintwork of these cx100:s would also need some work since they are quite scrached but not so much that the aluminium would show. Got any ideas how to make them look better?
  • 08-05-2008 3:24 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    hi there
    don't know what the finish of the white -satin gloss etc if satin to glossy try some silver polish on the surface (out of sight to get a feel for its performance )
    salut ala france
    tony s
  • 08-05-2008 4:06 AM In reply to
    Nooooo!
    The white finish is VERY delicate. There is not a lot you can do to restore it other than a respray with car paint.
    Regards Graham
  • 08-05-2008 8:01 AM In reply to
    • Craig
    • Posts 4,855
    Vandelay:
    Priced some up last month and they were £25 each.
    CraigSmile
  • 08-06-2008 12:04 PM In reply to
    Thats a lot more than new foams , but if I dont manage to change them properly I guess have to pay the price.
    The white paint is tricky indeed since it is not glossy, but I will try to sand it with really fine sandpaper and see what happens. That is what I have to do anyway if I paint them over. At least I now have something to do  in the evenings :)
