Thanks to Dillen, I have a new tacho and fitting it, & plugging in, the turntable spun at 33 & 45 1/2 way there!
I went to play and the arm moved to the edge of the record and stayed there. After that none of the buttons would work.
Unplugged and plugged in again and the 1amp fuse in the shaver adapter went bang. (don't want to cut off the continental plug yet)
I want to replace the caps but HOW does the electronics come out? The manual says lift the panel at the back then remove the retainers?
I can'tsee how to lift the back and it seems firmly in place. There are 2 little holes one in the pickup receptacle and one under a rubber stop Atre there screws in there? i can''t see any
Please advise.
Peter
