David,
It depends on which version of AVANT you have.
If you have a Mark III AVANT DVD (Type numbers 846X) with TV software version 15.1, then you CAN do what you wish.
In the above version of TV software B&O implemented a so called SOFT standby setup on STB
This feature means that you can decide when, or if, your STB should enter Standby.
