Latest post 07-17-2008 12:56 PM by Craig. 8 replies.
Page 1 of 1 (9 items)
  • 07-16-2008 5:01 PM
    A "slabby" record player
    Hi all:
    My father has put away his turntable and dismantled his old HiFi seperates/speakers from the 80s because they do not go with modern decoration.
    I would get him a B&O turntable but think we/he will be faced with the same problem. I would therefore like to get him one of those ones that has a stone/stone looking base  and just the tone arm. You know, like a circular chopping board but thicker. I am not really into vynl myslef and I only saw one recently in a branch of Seven Oaks. I guess that a number of high-end manufacturers make them but I was wondering if anyone has any ball park figures for these either new and/or second life and whether they are any good?
    Graham
  • 07-16-2008 5:10 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: A "slabby" record player
    Graham do you mean these type Turntables? If so, all I can say is they are very expensive new and I would think they tend to hold their price used too.
    CraigSmile
  • 07-16-2008 5:59 PM In reply to
    Hi:
    Yes like those but they look slightly more complicated than the other ones I have seen. I gather those ones are a couple of grand each at least?
  • 07-16-2008 6:08 PM In reply to
    • Craig
    • Posts 4,855
    Yes, they are around that price I believe. Dread to think how much a cartridge is.
    CraigSmile
  • 07-16-2008 6:25 PM In reply to
    The good thing about a lot of these style of turntables is that they use a universal style cartridge mount so you could always start of with a cheap cartridge and upgrade it when funds allow!
    If you are looking for a decent secondhand turntable I recommend contacting Walrus Systems in London a call....they usually have a range of secondhand turntables available!
  • 07-17-2008 4:47 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
  • 07-17-2008 5:13 AM In reply to
    One of the later Beosystems in white could be a decent option, the design will have dated less than many designs from that period. He could then add some modern B&O active speakers such as a pair of Lab 4000's.
    Simon
  • 07-17-2008 7:15 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    The Project RPM6 and RPM9 are both fantastic decks and would suit your needs. The RPM 6.1SB is generally around £550 or thereabouts.
     Weekly top artists:
  • 07-17-2008 12:56 PM In reply to
    • Craig
    • Posts 4,855
    Project make a good product IMO, I have a Debut III which I use with my BS3000. Also use one of their pre amps too.
    CraigSmile
