Latest post 07-16-2008 2:28 PM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 07-16-2008 12:36 PM
    • snoby
    • Not Ranked
    • Joined on 07-16-2008
    • Posts 3
    Beolink 1000 & Beomaster 6500
     I can't make this combination work, can anyone help? The remote should be working, which mean I've tested if it gives any signal (camera in front of the IR)
    I've read that you could press sound --> 1 --> store whilst the Beomaster is in standby, but it still doesn't work.
     Help? Smile
  • 07-16-2008 12:38 PM In reply to
    Re: Beolink 1000 & Beomaster 6500
    That should work! The 6500 needs to be in Stand By. If it doesn't work, does it work with any other remote?
  • 07-16-2008 12:46 PM In reply to
    • snoby
    • Not Ranked
    • Posts 3
    Well it works with the master control 6500... The Beolink 1000 is from a television and in the bottom is says video terminal, might that be a problem?
  • 07-16-2008 2:28 PM In reply to
    The video terminal was designed for use with TVs. Is it this one? If so, you can't select an audio source which is why it won't work.
