Latest post 07-12-2008 6:26 AM by Piet van der Zalm. 1 replies.
Page 1 of 1 (2 items)
  • 07-12-2008 5:54 AM
    • OKF
    • Top 500 Contributor
    • Joined on 02-22-2008
    • Posts 204
    is the new SW 1.34 and new FW worth installing
    Hi
    I am using 1.10 and do not know te FW but is it worth upgrading? What is the difference between the two, can somebody give a brief info? Is it right that all programming needs to be done from the start?
    Best regards Oliver
  • 07-12-2008 6:26 AM In reply to
    Re: is the new SW 1.34 and new FW worth installing
    OKF,
     you can read more about version 1.30 at the Beo5 remote forum, topic Beo 5 configsw 1.30a out now
    When you going to upgrade, be sure you have version 1.34 of the firmware files (software tool remains 1.30). There is a bug in the firmware 1.30 and 1.32.
