These may be repairable and worth trying simply to keep as many of the drivers in circulation.
Likely what has happened is that the voice coil has partially detached itself from the membrane. This happened to the midrange on my M150.
The fix is to dismantle the driver then carefully re-adhere the coil back to the membrane. Use "super glue." Place a tiny drop on the loose end and gently secure it to the membrane. Once it is held in place you can run a very tiny bead along the edge that doesn't have glue. Less glue is better so use sparingly.
You want to use a light density adhesive because extra mass will affect the transient response of the tweeter.
Now that you have an extra pair, you can experiment :)
Derek
