seanklemis: hello please help i just got my MK3 and dont knwo what device to choose as SKY HD
i have been into customer service menu and there are cinema timings but no alternate speakers settings liek ti says in the reference book?
hello hwo do i tell if i have 4.24 installed and there is a menu item called 60Hz on or off this is set to no, should i change this to yes?
hello also how do i use the Puc to conrtol the ps3 i know the dealer is goign to flash the puc with PS3 but ps3 uses a bluetooth remote, has anyone done this
Also in the menu for cinema timings it does not allow under 11 seconds to return to TV mode
I cant help you with the Sky HD box, but you can just try all the devices one by one, until you find the one that works.
You can see if you have 4,24 if you go into customer service menu, and look under SW, the top value is the one that should read 4.24.
What do you need to change Cinema Timings for, do you have a projector ?
To control a PS3, you need the "Sony Playstation 3" PUC in you STB table, and a NYKO remote, this remote is a USB dongle with IR receiver,that you put into the PS3, and then the IR cable from BV7 is put on this USB dongle.
/Weebyx
