Hi Michael,
I have seen an Avant stand disassembled in detail as I had a similar problem: the tv would not react to STAND 0,1 and 2 commands, but would react to STAND, left/right arrow though kind of struggling when turning. This happened after the tv was moved (when we moved to a new place), indeed.
So it might be a little plastic part (picture enclosed) got demaged and needs to be exchanged which is no problem at all.
On the pic you can see there are two dents visible on the circularly shaped part of the component: they should not be there, instead there should be two symetrical protrusions obviously chipped off ...
Hope this helps.
