Latest post 07-10-2008 8:53 AM by Friedmett. 3 replies.
Page 1 of 1 (4 items)
  • 07-09-2008 9:34 PM
    • julene
    • Not Ranked
    • Joined on 07-10-2008
    • Posts 1
    beomaster 2000 speaker issue
    Thanking you in advance for any help anyone might be able to give me. I recently purchashed a Beomaster 2000 and after plugging in my second set of speakers I immediately lost some volume. I can not get the volume to go above 40 and when I keep trying to push it more the receiver turns off completely.  When using only one set of speakers everything works wonderfully. What should I do. Thanks again.
    Filed under:
  • 07-10-2008 2:15 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: beomaster 2000 speaker issue
    Welcome to Beoworld !
    What brands and models of speakers do you have ?
  • 07-10-2008 4:20 AM In reply to
    I take it that it is the 80s BM2000. Sounds like it is the protection circuit working. I would check the speakers cables and make sure that there is no short or poor connection. Martin is obviously wondering about the load of the speakers - if they are both very difficult to drive, the amplifier will try to protect itself. It probably needs a service - new capacitors and some variable resistors - they do gradually go out of spec and may well cause symptoms as you describe.
  • 07-10-2008 8:53 AM In reply to
    If it's Beovox X types then find some better speakers like the Beovox S-45.
    Beovox X series are B&O's most horrible sounding speakers. The 2000 sounds good though.
