1st March February 2012
Latest post 12-06-2008 5:38 PM by Dave. 9 replies.
07-08-2008 2:23 PM
beobeo
- Joined on 04-16-2007
- Spain
- Posts 953
You need the original Dolby Surround module, that comes as an option in the BV3-32 and as standard in all BV Avants. You need the one with 5 powerlinks as I believe the older one with 4 powerlinks will not work in BV3's. If you wait until I get home this afternnon european time I can give you the part number. I'm not sure you can still get it from a dealer, the chances are that is discontinued. Your best option will be probably e-Bay or post it in the wanted section of the Forum. Obvioulsy the module I'm mentioning will only work with B&O loudspeakers... if you intend to use non-B&O ones the solution is not that straight forward.
meandmyshadow
- Joined on 04-17-2007
- Posts 339
Graham1982: Aren't b&o supposed to keep stuff in stock for ten years after it has been removed from the range?
For spares yes but not for accessories. I suspect the problem will be software related, you can't just stick the DSS module in and hope for the best, you need to replace the TV software to the correct level - you'll have to visit your dealer for that.
dylan
- Perth, Australia
- Posts 117
From memory cost me about AU$300 but that included guy coming to house and fitting it together with a new STB-C chip. Didn't need software update for 3yr old TV
BS3200 BV7 BV3 BL8000 BG4000 BL4500 PC2 BG5500 MX4002
bentleybaz
- Joined on 07-08-2008
- north yorkshire ENGLAND
- Posts 5
thanks BEOBEO, and others for your info. I had the AV9000 with it built in , but updated when wanted DVD instead, i got beovision3 but forgot about the set up for other speakers. i have 2 of the 4 outlet cards, off of ebay, ( damm it lol ) . will try and source a 5 outlet card. And yes the speakers are B & O to connect up, as the old system.!! Davanyone has such a card. message m e£££££ waiting lol davidthomasames@hotmail.com
richtoy
- Joined on 09-20-2007
- Valkenburg, Netherlands
- Posts 184
BeoVision 3-32 Surround module questions....
Hi Did you find one of the modules for a BV3-32? Did you get a quote from a dealer?
I have just brought an imaculate BV3-32 for 400 euro but it came without the module  If a module is reasonably priced then I might upgrade but then I would need to start buying BeoLabs  Is it possible to drive the tape inputs of a quad BeoMaster (3400 or 6000) from the Front/Rear output from a surround module? Can the subwoofer output of the surround module drive a non B&O active subwoofer? Regards Richard
Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
Dave
- Brisbane, Australia
- Posts 2,328
dylan:From memory cost me about AU$300 but that included guy coming to house and fitting it together with a new STB-C chip. Didn't need software update for 3yr old TV
WOW! thats cheap. For Beocenter 1 i was quoted $1000 for the dolby surround card and $700 for a new back cover to be fitted to accommodate the change... crazyness
Page 1 of 1 (10 items)
