1st March February 2012
Latest post 07-11-2008 9:22 AM by Dave. 18 replies.
07-08-2008 12:22 PM
krdale
- Joined on 07-08-2008
- Posts 2
Hi all, Does anyone know if it is possible to get a hold of or get the BeoLab 5 produced with chrome details in contrast to the standard model with the steel "plates"? I have a friend with a woman in the house where everyting has to match, and this room is "chrome-room", no way the steel is welcome! :)
beocool
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
It is possible to polish aluminium to a mirror-like finish. The end result will be slightly different in colour than chrome.
beocool
- the Netherlands
- Posts 5,514
By the way, it's possible to apply a layer of chrome to aluminium, but it's extremely difficult. Aluminium corrodes very quickly. Thoroughly cleaned and rinsed aluminium gets oxidized within one second. To prevent this from happening you first need to apply a layer of nickel you'll need to put the aluminium object in a bath with a solution of sodium hydroxide and sodium-zincate. Now the aluminium-oxide dissolves and a layer of zinc (15-30 microns) is formed round the aluminium, which acts as protection against corrosion and fills any scratches in the seemingly smooth aluminium. Now you'll have an object that behaves as if it is zinc. Unfortunately, you can't apply chrome to zinc. First you'll have to apply a layer of copper; otherwise the chrome will come off very easily. The process for applying copper uses a solution of cyanides which are highly toxic. Now you can apply a layer of chrome to it. The chrome itself is really just colouring, and no more than 0.5 microns thick. The process as described is a simplification of the actual process, but my knowledge on the subject is not that good I'm afraid.
camshaft
- Joined on 04-16-2007
- Pennsylvania, USA
- Posts 575
Polishing wouldn't be practical. If you really wanted to, you could remove the aluminum sections and send them to a place that chromes automotive parts. They'd be familiar with the process, and the speaker owner wouldn't have to worry about the details such as those beocool provided. This would probably cost less than having B&O do a custom job on them. Austin
-Austin (resident audiophile skeptic)
krdale
- Posts 2
Thanks guys, i really appreciate all the input, i'll come back with any other questions and keep you updated on how this goes. How difficult is it do disassemble the Beo lab 5, so that the alu "plates" can be modified? And does anyone know what it will mean if the thickness increase with a millimeter or two..? Which i guess would be the result if a its got chromed? Or would all the new layers be extremely thin..?
beocool
- the Netherlands
- Posts 5,514
krdale: Thanks guys, i really appreciate all the input, i'll come back with any other questions and keep you updated on how this goes. How difficult is it do disassemble the Beo lab 5, so that the alu "plates" can be modified? And does anyone know what it will mean if the thickness increase with a millimeter or two..? Which i guess would be the result if a its got chromed? Or would all the new layers be extremely thin..?
The new layers can be extremely thin (in total about 100 microns or 0.1 millimeters I guess) I'm not sure how the plates are attached, but even if the plates are 0.1 of a millimeter thicker on either side, reassembly can proof tricky, if not impossible. Polishing the aluminium, like Puncher suggested is in itself a good idea, but the colour of mirror finished aluminium differs from chrome. The chrome has a slightly more blueish colour. Not anyone can recognize the differences between mirror finished aluminium, mirror finished stainless steel or chrome plating, so maybe polishing might be the best option, after all.
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
Puncher: There was a guy here on-site that was able to re-process the aluminium panels/speaker housings to a mirror-like finish. I forget his name but he may have produced some BL4000's for LEE as a demo - maybe LEE can help.
Andy is his name.
Mr10Percent
- In Transit
- Posts 441
I dont think it will be easy to change the aluminium disks on the BL5. First, the supplied disks are very thin alu. Second, they are bonded onto the main lens by a rubberised bonding agent. This is thick and tarry. The bonding agent is allowed to ooze into 6 - 8 circular groves on the inside of the lens before the alu disk is pressed on. Thus to replace the alu disk one is more than likely to damage the original (prising off against the glue) and would also need a serious effort removing the old bonding adhesive from the lens. Finally, new bonding adhesive would be required to eliminiate vibration between the new (coloured) alu disk and the lens. To see what I mean, there is a video on the B&O site (factory tour) which shows this. Also look at the X-ray pictures of the BL5 and see the concentric grooves in the lens. 10%
beocool
- the Netherlands
- Posts 5,514
So the discs are bonded. Agree with 10% that this is nearly impossible....
GuyHui
- Joined on 03-17-2007
- Posts 1,560
Jandyt:
It's even more expensive than my car, as a wreck after an accident... Guy
--= "Everything gets done with Patience" =--
--= "Less is More" - Mies Van der Rohe"
--= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
Ericvr6
- The Netherlands
- Posts 205
Jandyt: See! It's a piece of cake! Now, anybody got some BL5s I can practice on? I must admit, I got better at it as I practised, I just recently silver-plated an Audi A8 for one of my mates
what a nice job looks great
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Ericvr6: Jandyt: See! It's a piece of cake! Now, anybody got some BL5s I can practice on? I must admit, I got better at it as I practised, I just recently silver-plated an Audi A8 for one of my mates
Och! It was nothing.
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Jandyt: Ericvr6: Jandyt: See! It's a piece of cake! Now, anybody got some BL5s I can practice on? I must admit, I got better at it as I practised, I just recently silver-plated an Audi A8 for one of my mates
Completely off topic - but did you know that jandyt was the model for Oor Wullie!
beocool
- the Netherlands
- Posts 5,514
Puncher: Jandyt: Ericvr6: Jandyt: See! It's a piece of cake! Now, anybody got some BL5s I can practice on? I must admit, I got better at it as I practised, I just recently silver-plated an Audi A8 for one of my mates
So Andy is lying about his age, then?
a2bur
- Joined on 04-20-2007
- Posts 262
My dealer dropped off some Lutro bits last night and also had the larger of the two ally discs from a Lab5 and wondered if it could be converted into an ash tray or something , somehow it got a ding in it and had to be replaced , it has the moulded plastic part attached . With great care it could be polished , you or whoever would have to take time and avoid any heat build up and the outer edge done by hand . Can't see any way of separating the ally from the plastic without destroying one or the other . Richard
Dave
- Brisbane, Australia
- Posts 2,328
It's easy, if B&o can't do it for you, then forget it and drape an acoustically transperant curtain infront of them - if you can't stand to look at them - ummm They're gorgeous creatures and i can not imagine them being a mismatch in any type of environment. However, BL5's with chrome discs would look incredible. Hooly dooly, B&o should offer it as an option. Why oh why don't they offer any options with the BL5's?
Page 1 of 1 (19 items)
