Latest post 07-08-2008 7:41 AM by mor. 2 replies.
Page 1 of 1 (3 items)
  • 07-08-2008 6:40 AM
    • majand
    • Not Ranked
    • Joined on 02-26-2008
    • Helsinki
    • Posts 72
    • Gold Member
    Opinions of MX5500
    I'm considering to buy a Beovision MX5500. I'm intrested on comments about it's picture and sound quality. I have an Avant, so I guess they are not exactly in same league, but this on would come to my freetime home.
    Could this set be controlled with Beo4?
    Anything special to be aware of? I read that there is some series of MX5500 with an other chassis than B&O. How do I tell the difference?
    Thanks,
    Pekka
  • 07-08-2008 7:11 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Opinions of MX5500
    hi
    just bought 2 of these for peanuts - i am well pleased with the performance - however this is a comparison with an early 40cm lg set now some 7 years old!
    points to watch - foam rot on speakers - both mine had this problem however easy to repair / replace with rings from Goodhifi(see ebay) less than 10-12€
    i use a beolink1000 so no idea of beo 4 controller
    hope thius helps
    tony s
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 07-08-2008 7:41 AM In reply to
    • mor
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Cologne
    • Posts 104
    If the set is in good condition you should not have any issues with it. Be aware though that some 5500s are two-way IR though and will be a pain programming without a BL5000 or 7000. Day-to-day operation with a Beo4 or 1000 won't be a problem.
