Latest post 07-07-2008 5:39 PM by cowier. 2 replies.
Page 1 of 1 (3 items)
  • 07-07-2008 5:05 PM
    • cowier
    • Not Ranked
    • Joined on 07-07-2008
    • Posts 3
    Connecting a Beocenter 2300 to a Sony Bravia
    Hi, please can someone help!
    I want to connect my Beocenter 2300 which has 2 front speakers and also a pair of Beolab 6000 (straightforward connecting speakers to my Beocenter at least!) to my new Sony Bravia that I purchased. Apparently, I need a 7 pin to phono lead so that the 7 pin goes into aux of Beocenter and the phono into TV, is this correct? I am having great difficulty in being able to find / purchase this lead, can someone help please, much appreciated. Regards Rod
  • 07-07-2008 5:11 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Connecting a Beocenter 2300 to a Sony Bravia
    Hello and welome to Beoworld. You will only need a 5 pin to Phono lead as the outer pins are not required for what you want. These only carry data for use with other B&O products. This should make finding a lead much easier.
    CraigSmile
  • 07-07-2008 5:39 PM In reply to
    • cowier
    • Not Ranked
    • Posts 3
    Thanks Craig, appreciate your help.
    B & O in Edinburgh thought I would need 7 pin, that's saved me a lot of grief, much oblighed.
    Kind regards
    Rod
