Latest post 07-02-2008 5:44 PM by Alex. 2 replies.
Page 1 of 1 (3 items)
  • 07-01-2008 4:03 PM
    Troubles connecting an external DVD player to Beovision 6-26
    I have tried connecting my DVD player to my Beovision 6-26 TV, but it doesn't seem to work. When I try to switch to the V-AUX channel, I only get a black screen, and when I go to AV on the "list" on the remote and push "GO" nothing happens. My DVD player is connected through a SCART cable, and it's working just fine on my old TV.
     Any help would be lovely
     Cheers
  • 07-02-2008 4:38 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Troubles connecting an external DVD player to Beovision 6-26
    Did  you assign the V.Aux to the Scart input the player is connected to?
    21 pin Scart cable?
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 07-02-2008 5:44 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Under the 'Connections' menu, you must assign the socket your DVD player is connected to to a button on your remote.
    The 'AV' function isn't for enabling a scart input, it allows you to listen to a B&O sound system through the TV's speakers at the same time as watching something else.
     Weekly top artists:
